1996-97 Ignition Switch compatiblility
Old Apr 15, 2026 | 11:31 PM
HOGMAXXING's Avatar
Default 1996-97 Ignition Switch compatiblility
Hello all, I was looking to replace the ignition switch in my 96 civic, but the easiest switch to find is part # 35130-S04-305, which I see is compatible with the 98-00 civics. Since the ignition switch assembly is seemingly the same from 1996-2000, would it be safe to use this part in my 96, or are is there wiring or other differences I should be aware of before proceeding? Thank you for your time.
Old Apr 16, 2026 | 07:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1996-97 Ignition Switch compatiblility
To the best of my knowledge, the only difference between the ignition switch pigtails in Civics from 1992 to 2000 is the orientation of the wiring in the brown plug that connects to the under-dash fuse box... (as well as the zip-tie clips that secure it to the column and under-dash wiring). You can purchase the '98-00 version and simply compare the wiring order to your current one... move any wires necessary, and plug it into your car. All will be fine.
migizzel
Dec 5, 2005 03:46 PM
chito_zan
Aug 10, 2004 05:27 PM
H22Prelude
Jan 20, 2003 06:53 PM
