P0715 Appeared on my 97 Accord
So around 4 month ago I received a check engine light with the code P0715 so i replaced the input shaft speed sensor and then it went away. Then it appeared again a month ago so I had replaced the output sensor and went away again. Now it has appeared once more and i don't know what to do, the problem I was able to notice is that when I am driving the rpm goes real high so i let go of the gas and then the gear shift, after that it drives like normal switching gears as it should, this issue appeared after i was in traffic stopping and going repeatably in such short burst, I checked the transmission fluid and it seemed normal, both the sensors seemed to work, I believe that my transmission is ruined but i was wondering if anyone could help narrow down the issue
willela12
Sep 17, 2017 04:14 PM
brigman262
Jan 6, 2016 01:12 AM
Alwayscali
Sep 29, 2012 04:29 AM
