Stock b18c6 duty cycle
Old Oct 22, 2025 | 11:56 AM
Pablomg's Avatar
5 Year Member
Default Stock b18c6 duty cycle
240cc 50psi 97-98% duty cycle
It has been proven that it loses HP starting at 90%
So in theory with 60psi lower than 90% should be gain hp?
Old Oct 22, 2025 | 08:42 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Stock b18c6 duty cycle
It isn't losing HP just because the fuel injector duty cycle is above 90%. Until you lose fuel control, the duty cycle is immaterial. When the engine leans out uncontrollably, then you will experience power loss, but not until then. If your A/F is proper and your ignition timing is optimized... you will make maximum HP.
Old Oct 23, 2025 | 05:01 AM
Pablomg's Avatar
5 Year Member
Originally Posted by JRCivic1
No se pierde potencia solo porque el ciclo de trabajo del inyector de combustible supere el 90 %. Hasta que se pierde el control del combustible, el ciclo de trabajo es irrelevante. Cuando el motor se empobrece sin control, se experimenta pérdida de potencia, pero no antes. Si el aire acondicionado funciona correctamente y el tiempo de encendido está optimizado, se alcanzará la máxima potencia.
I mean humbleperfomance and another channel that check it with some RC, so you say that the original ITR would be losing hp?
It would be interesting to do a test, since 90' ​​technology is not the same as it is now
Old Oct 23, 2025 | 06:51 AM
spAdam's Avatar
Loved
Community Favorite
If we’re talking about a totally stock B18C5/6 then no, there’s no power to be gained by simply increasing the fuel pressure. Honda already increased it from 3 bar to 3.5 bar (50.75 psi) on those engines to make the 195-205hp targets without upsizing the injectors. That being said, they are pretty much at their functional limit out of the box.
You could add pressure to give yourself more headroom for modifications, but it’s pointless without a re-tune and these old EV1 style injectors and your stock pump and wiring) don’t do so well at higher pressures. Better bet would be be to swap in a set of reasonably sized for your goals modern injectors and re-tune.
Old Oct 23, 2025 | 08:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Post your dyno sheet (HP, Torque, and A/F on an RPM "X" axis) so that I can explain this better using your data as a real example.
Old Oct 23, 2025 | 09:20 PM
Pablomg's Avatar
5 Year Member
I'll run a test on my H22 310cc OEM K20 (afr 13:1 43.5psi 95% @ 60psi afr 13:1 lower than 90%) and report it here. My dyno is always 1/4, so that's just indicative
Old Oct 24, 2025 | 08:50 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Ready when you are.
hbyrd8701
Nov 19, 2008 09:41 PM
prelude_93vtec
Acura NSX
Dec 15, 2007 11:12 AM
