thanks a million for your help but still not certain which one is mine according to the link it’s either OBD0 SOHC which I originally thought it was because it states the mpfi that mine has but still confused because also states that the DOHC has a black valve cover with 4 bolts on the ouside of the cover which mine also has soooooo……..
is that last picture you posted your engine? that is an OBD0 non-VTEC SOHC ZC (if it says ZC on the block) with the stock DPFI intake manifold from the 88-91 Civic/CRX DX model - it is not MPFI - probably started out as a dual carb SOHC ZC - does it run?
52717031[/url]]is that last picture you posted your engine? that is an OBD0 non-VTEC SOHC ZC (if it says ZC on the block) with the stock DPFI intake manifold from the 88-91 Civic/CRX DX model - it is not MPFI - probably started out as a dual carb SOHC ZC - does it run?
this is the DOHC ZC (MPFI)
roger that yes that’s my engine you are correct do you know if possible to swap it to mpfi what that requires and also I want to auto to manual swap it do you know what transmissions are compatible??
I have a 91 civic dx hatch non vtech and thought it was a D16 but apparently it’s stamped ZC and from what I have researched it’s JDM ??
ZC stamped motors came in many different flavors. It's not just DOHC 1.6L d16A9. ZC was also stamped on SOHC and VTEC engines.
If it's SOHC and no VTEC, it could either have been carbureted or MPFI. The obvious difference will be an open port (or already blocked off plate) in the back closer to the distributor side. The cams are slightly different, and the MPFI is nearly identical to the d16A6.
Either way, the choice of intake is freely up to you and what you already have or whatever will bolt on just like a d15 can be converted to MPFI.
Transmissions will bolt on the same just like any typical D series.
