civic VX d15z1 ignition timing
Old Jul 1, 2014 | 07:53 AM
jlk16188's Avatar
Default civic VX d15z1 ignition timing
So i have been playing with my VX now for 2 years and cant seen to get the timing to act the same way as my novtec CRX.
With the mechanical timing believed to be correct and using a timing light, I can set my ignition timing pretty dead nuts on where it needs to be but the distributor is almost at its max advance. I mean only a hair away.
I just tried to advance the timing last night and I have the timing set at the advanced mark on the crank pulley but the distributor is completely maxed out at its travel.
Is this normal? I am following the timing procedure correctly and jumping the service connector while setting the timing. It just seems like I should have more adjustment than I actually do.
The car run fine and gets roughly high 40's and low 50's but has an occasional miss when hot at idle and in lean running at constant highway speeds.
I do not know the history of the motor whether anything has been machined. I did replace the timing belt and am fairly certain it is lined up perfect. I just want some input from other VX owners before I start tearing it back apart to check the mechanical timing for the third time.
Picture for interest
Old Jul 1, 2014 | 08:36 AM
slogfilet's Avatar
Default Re: civic VX d15z1 ignition timing
Are you 100% positive the timing belt isn't off a tooth? Due to the angle when looking at the timing markers on my D15Z1, I found that mine was off a tooth even though it "looked" ok at first.
EDIT - For a bit more detail, when I was putting the timing belt on, it looked like it wasn't possible to line up the timing marks on the timing belt cover. Keep in mind that when you're looking down at them from the top, you're not seeing them quite right. I visualized them straight on, and that's when I realized I was off a tooth (that, and I had issues at 2500+ rpm with significant loss of power).
Do you have any aftermarket or non-stock parts installed?
Old Jul 1, 2014 | 08:39 AM
Former User's Avatar
If you can set the ignition timing to the red mark with the engine idling to spec and the service connector jumped, then it's fine.
Old Jul 1, 2014 | 09:07 AM
jlk16188's Avatar
I wasnt sure if it was lined up so i took it all apart and set an Allen wench between the gear teeth to act as a pointer and lined up the cam to the correct arrows on the plastic rear cover.
I have nothing aftermarket on the car and it runs fine.
The ignition timing is set within tolerance I am only concerned that the distributor is completely out of travel to go any further if I wanted to advance it past the advance timing position.
Old Jul 1, 2014 | 09:27 AM
Old Jul 1, 2014 | 09:31 AM
slogfilet's Avatar
^^ What he said, then. To be honest, I would have questioned it myself if that much adjustment was necessary to get the timing right. But I guess right is right.
Thinking about it, I'm not sure you'd be able to actually line it up (even with full adjustment) if you were a tooth off. In Ron we trust.
tony_2018's Avatar
Fish Twig
I think he's trying to advance timing, but is the OP jumping the service connector to do this?
Old Jul 1, 2014 | 09:42 AM
jlk16188's Avatar
Yes, As stated i have been jumping the service connector and following the correct procedure. I can adjust the timing to factory spec and also the advanced or retarded spec lines on the crank pulley as well. I have a ton of adjustment to retard the timing all i want but with the distributor hard against the stops I can just barely advance it to the advanced line.
Old Jul 1, 2014 | 09:51 AM
tony_2018's Avatar
Fish Twig
Take a snap shot of this advance line.
Old Jul 1, 2014 | 09:54 AM
Don't obsess over a non-problem.
Old Jul 1, 2014 | 09:57 AM
jlk16188's Avatar
there are three lines in a grouping and one all alone (TDC line) the center of the three in the grouping is the factory set timing line, I dont remember the degrees off of it but the other two are an 1/8" to the left and an 1/8" to the right, they are the advanced and retarded factory position spec lines.
All it is are 3 lines in a group less than 1/2". Standard on all 92-95 d series motors
Old Jul 1, 2014 | 09:58 AM
jlk16188's Avatar
thanks for your advise.
Old Jul 1, 2014 | 10:47 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Is this considered true if the distributor is at one extreme or the other to get to the red mark on the crank pulley?
I would think this would indicate being 1 tooth off?
I mean yes it's in time ignition wise but off mechanically, isn't it?
Old Jul 1, 2014 | 10:53 AM
jlk16188's Avatar
My experience has been that if it was one tooth off then I could not get the ignition timing set at all close. But I experienced that on a d16a6 and not a d15z1.
I was hoping other VX owners could tell me if they have advanced their timing and where their distributors are sitting compared to mine.
Old Jul 1, 2014 | 11:01 AM
Yes
No
No.
If you are able to set the ignition timing to spec, then by definition the mechanical timing is correct.
Old Jul 1, 2014 | 11:02 AM
Correct
Old Jul 1, 2014 | 12:32 PM
tony_2018's Avatar
Fish Twig
But to advance it that far just to get to that 1/8 mark is kinda weird. I never had to do that with my d15b. Oh well no point in obsessing......
Old Jul 1, 2014 | 02:17 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I gotchya, so the full range of the distributor is more like the equivalent of half a tooth? Making the middle setting of the distributor to each extreme equal to say a quarter tooth?
Would that be a more accurate relation of the ratios?
Old Apr 28, 2026 | 04:23 AM
EGproceeding's Avatar
I can’t even get my ignition timing correct. I’m like two lines way from the red mark but distributor is maxed to advanced. Does that mean my cam is off?
Old Apr 28, 2026 | 07:55 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Not necessarily. Do you have the original OE distributor installed or an aftermarket one of some type ? If it is the latter, it is very common that these lower cost economy distributors from local parts stores or EBay/Amazon have the internal sensors machined into the housing incorrectly, causing the timing of the housing to be highly retarded compared to an OE housing. Thus, maxing the advance all the way usually only gets you to 12 or 13 degrees of initial advance... certainly short of the 16 degree mark on your crankshaft pulley. You could try to open up the slots a bit more with a drill or dremel to see if you can get a bit closer.
Old Apr 29, 2026 | 04:58 AM
im pretty sure it has the Original distributor, it does say TD-42U. I never changed it out, I did rebuild it though and since then hasn’t given me any issues.
I was thinking the same thing, to dremel it out enough LOL have you done that or know anybody who has? It wouldn’t cause any issues?
Old Apr 29, 2026 | 05:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Is the "TD-42U" identifier stamped into the edge of the housing or is it on a sticker ?
I have modified the slots on distributors in the past in order to more accurately set the base ignition timing. I haven't experienced any issues doing this.
alperx
Engine Management and Tuning
Jun 7, 2011 05:00 AM
kixcrx
Nov 10, 2006 10:33 AM
miksew
Jun 7, 2006 08:03 AM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
3rdGteg
Dec 1, 2002 08:15 AM
