wrong Torque spec diagram?
Old Apr 5, 2018 | 01:53 PM
K-G's Avatar
K-G
Default wrong Torque spec diagram?
i am trying to find the correct torque spec for the upper valve assembly for D16z6 (po8-6 head) and I get this diagram.
However my bolts are not 6mm & 8. They’re 10mm and 12mm.
Should I still follow that spec?
Here is the diagram
Old Apr 5, 2018 | 07:15 PM
egsleepercivic's Avatar
Default Re: wrong Torque spec diagram?
From the Helms
Old Apr 5, 2018 | 08:34 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
They are actually 6 and 8mm bolts... but that reference is the threaded shank diameter. The 6mm bolts actually have a 10mm head on top and the 8mm bolts have a 12mm head on top. So you are saying the same thing even though you don't realize it.
Also, for reference... a 10mm bolt will have a 14mm head, most 12mm bolts will have a 17mm head, and 14mm bolts will have a 19mm head.
Old Apr 6, 2018 | 09:00 AM
K-G's Avatar
K-G
AHHHH ok That’s weird but thank you very much !
This is my My first “rebuild” on a motor and I just wanted to make sure I’m torquing everything correctly and making sure my information is correct where I’m getting it from.
Thanks again I appreciate it
orangeracer
May 23, 2006 03:32 PM
junglerunna
Jan 20, 2005 09:31 AM
Archidictus
Nov 26, 2004 03:15 PM
