WhiteSlipsWithStickers Refresh Build 2013
Old Apr 17, 2017 | 06:18 AM
  #351
WhiteSlips's Avatar
Default Re: WhiteSlipsWithStickers Refresh Build 2013
I've been enjoying the car and haven't done much to it since I've had it running. I did pick up a comptech icebox from a good friend of mine. This intake I think was bought brand new by another old friend Nick who's car I always looked up to when I was first getting in to Hondas. It's pretty cool to have a part of it on mine. I'm just the caretaker until Nick's car is running again though and then I'll give it back to him. The diff is bad and whining, so have to pull the trans again, but will be installing an MFactory LSD this time which should make the car a little less scary to drive when it loses traction.
Old Apr 17, 2017 | 11:14 AM
  #352
ej2guy21's Avatar
I like the first picture a lot, I have a similar one of my coupe. Your hatch makes me really wish I kept mine. The only thing I would change about your car is putting on the clear OEM corners. Keep up the good work, you don't see many EG/EJ's that are in good condition anymore.
Old Apr 17, 2017 | 11:42 AM
  #353
WhiteSlips's Avatar
Thanks! I have the EG6 clear corners, some vision smoked corners and a set of old Ebay amber corners. I just get bored and switch them around sometimes. The first picture has the EG6 corners on the car. It's really hard to find any pre-2001 civic in good shape anymore. Theft killed a lot in the early 2000s, Rust killed a lot of them after that and stance was the final common denominator on destroyed quarter panels and busted up undercarriages.
Old Apr 17, 2017 | 12:01 PM
  #354
Casey's Avatar
looking awesome. Glad youre getting to enjoy it now that the weather is getting nice
Old Apr 18, 2017 | 05:32 AM
  #355
WhiteSlips's Avatar
Thanks man. I've been driving it around a little bit, but scared to venture too far from my house with the diff howling like it is. I just don't want to take it off the road when it's 75 and sunny everyday.....
Old Apr 18, 2017 | 03:51 PM
  #356
knuttveiten's Avatar
Looks great man... Super clean!
Old Jun 16, 2017 | 08:19 AM
  #357
WhiteSlips's Avatar
Nothing really to update, just been enjoying the car while the weather was nice. It's 98+ out now, so will probably take it off the road for now to get the LMAs in finally and pull the transmission to see what the issue is.
Old Jun 20, 2017 | 02:33 PM
  #358
chiprez's Avatar
Man, your car is a good example for what to do to all these young Honda kids out there. Keep it up.
Old Jun 20, 2017 | 02:47 PM
  #359
chiprez's Avatar
quoting for truth.
Old Aug 13, 2017 | 02:04 PM
  #360
Grahambo02's Avatar
Bump for the kickass cover feature on honda-tech.com. Congrats!
Old Nov 29, 2017 | 07:01 AM
  #361
WhiteSlips's Avatar
The new engine has been in the car a year now and I drive the car a few times a week. It's the first time in a really long time that the car has been turnkey and reliable which is really cool. I'm picking up S300 soon and will take it up to Humble Performance in Tulsa to get everything perfect on the dyno.
Old Nov 29, 2017 | 07:18 AM
  #362
GreatWave's Avatar
10 Year Member
Still looks great
Old Nov 30, 2017 | 03:44 AM
  #363
jim chuck's Avatar
Beautiful car man. I love the sexiness of simplicity
Old Dec 1, 2017 | 05:52 PM
  #364
ShinsenTuner's Avatar
No Jodas
Exciting stuff Chris!!
Old Dec 3, 2017 | 12:44 PM
  #365
Casey's Avatar
very nice sir. what is your breather setup? probably going to do one on mine at some point as well but dont want to do bungs on the valve cover. you running 1 or 2 -10s to that can or something else?
Old Dec 7, 2017 | 01:44 PM
  #366
WhiteSlips's Avatar
Originally Posted by not_so_jdm_eh2
Still looks great
Thanks guys!
very nice sir. what is your breather setup? probably going to do one on mine at some point as well but don't want to do bungs on the valve cover. you running 1 or 2 -10s to that can or something else?
Thanks man. Right now it's honestly just a hose from the stock breather port on the VC to the catch can. When I pull the trans again I'm going to install the OE block fittings in the back of the block and block off the PCV and run two -10s off of the OE breather barbs to my catch can/breather. I'm just going to use these fittings and then block off the breather port.
Old Dec 8, 2017 | 08:20 AM
  #367
.Grimace's Avatar
footwork mastery
Still love this build, between you, Casey and a few others you got me to buy an older Honda again, still waiting on spring for paint but then it should start moving quickly. A nice clean mostly OEM build like yours will always be classy.
Old May 17, 2018 | 01:58 PM
  #368
WhiteSlips's Avatar
I "unupgraded" my driver and passenger side engine/trans mounts back to stock replacements, got the test pipe welded up, and picked up some function form type 2s for a good deal from a friend of mine. The car feels pretty "stock" now when I'm just cruising around which is nice. Next upgrade will be an ASR subframe brace and ITR rear swaybar. I also have a chipped P28 with S300 that I'll use to get the car tuned by Humble Performance in Tulsa eventually. The OBD2 CTR ecu is still a little quirky so I'm hoping that fixes it.... Still just enjoying driving the car.
Old May 18, 2018 | 05:50 AM
  #369
Ericjergs's Avatar
I did the exact same thing with my motor mounts, idk your reason, but the vibrations from stiffer mounts made the car a pain to live with for me. I also just installed the ASR subframe bracing and a CTR swaybar, noticeably reduced understeer during autocross, you should like that upgrade!
Old Jun 6, 2018 | 09:54 AM
  #370
QuietOne's Avatar
Subscribed! Your car gives me hope!
Old Jun 27, 2018 | 09:18 AM
  #371
slowDB7's Avatar
Wow. I haven’t seen this thread in a long time. Still looks as great as last time I saw it
Old Jul 1, 2018 | 09:47 AM
  #372
jency17's Avatar
Thanks guys!
I've been having a little trouble removing those damn plugs off my block, what size and brand allen socket is that?
Old Aug 23, 2018 | 05:43 AM
  #373
WhiteSlips's Avatar
That's good to hear! Don't give up man.
Thanks! She's a little more dinged up than she was 10 years ago, but still pretty clean for her age.
I had a friend make me a giant allen wrench out of hardened steel at his machine shop when I did mine. They are steel and the block is aluminum so you'll have a good amount of corrosion buildup in there usually which is why they are so hard to get out. Try putting a pipe or breaker on the socket.
Old Aug 31, 2020 | 06:47 AM
  #374
WhiteSlips's Avatar
So somewhere about a year ago I had a main bearing failure on the B16B so I decided to go a bit bigger. GSR crank, ITR rods, new CTR pistons, everything balanced, lighter competition clutch flywheel, E85, DW300 pump, DW 800CC injectors, 12.8:1 compression, head refreshed, block honed, baffled oil pan, and then COVID hit and I couldn't get any of the ITR main or rod bearings I needed which slowed progress big time. Here's a quick rundown in pictures.... I have a few things to button up this week then I should be able to get it running.
I got pretty much everything buttoned up in the engine bay yesterday. Long HOT day but totally worth it.
Old Nov 17, 2020 | 08:52 PM
  #375
QuietOne's Avatar
Bruh I’ve missed this thread so much and HT in general. Life has been all over the place the last two years. I’m glad you’re still kicking with the car!
