H22 whining while accelerating and loss of power
Old Jun 8, 2017 | 07:39 AM
hondamyheart's Avatar
Default H22 whining while accelerating and loss of power
hi guys
My h22 lude recently developed whining noise and there is a loss of power specially at low end. Sometimes it runs perfect, vtec kicks in no problems and sometimes it losses power and vtec very weak.
Any ideas
Old Jun 8, 2017 | 07:57 AM
TimiK's Avatar
Default Re: H22 whining while accelerating and loss of power
whats your maintenance history? :
when you have replaced your ignition components?
cleaned valves (egr and so on)?
last time adjusted valves, changed air & fuel filters.....?
Old Jun 8, 2017 | 03:16 PM
holmesnmanny's Avatar
first check for codes, might need a tuneup.....spark plugs, cap, rotor
Old Jun 9, 2017 | 01:34 AM
I just replaced the cap and rotor last weak because the car wasn't starting. Spark plugs and fuel filter almost a year. Checked for codes nothing. Valves adjusted few months back
Old Jun 9, 2017 | 03:52 AM
TimiK's Avatar
- air filter and spark plug wires
- clean injectors/iacv/egr/fitv
- check does sensors work properly: map, iat and tps (and try calibrating tps), o2 sensors
- clogged cat might you give some trouble as well (usually when driving) - check cats condition
- check throttle cable (tight enough)
Old Jun 9, 2017 | 04:46 PM
Egr is blocked, iacv cleaned two months back, fitv blocked. I run straight pipe no cat. I will check the sensors and injectors. The throttle cable is little lose I will tighten it and see what happens
Old Jun 9, 2017 | 04:47 PM
HondaTechMan121's Avatar
post vid plz
Old Jun 10, 2017 | 03:41 AM
Originally Posted by HondaTechMan121
post vid plz
Will do. I just saw a cut in pcv valve hose and the hole was blocked with black **** lol. And oil is dripping in the exhaust. I will replace the hose and see from where the oil is dripping first.
Video of oil leak
Old Jun 11, 2017 | 12:37 AM
Could be the auto tensioner failing or one of the bearings failing or gone bad. I would probably do a timing belt kit if you narrow it down to the timing side.
Old Jun 11, 2017 | 04:45 AM
TimiK's Avatar
when was last timing belt job done?
If auto tensioner would be failed, you probably would have bent valves and a lot more problems than now
Old Jun 11, 2017 | 05:06 AM
Timing replaced around 7 months back.I pulled the valve cover but the belt looks in place and the marks on the camshaft are matched. How do I know that the tensioner has failed? The oil leak on the driver side I think because of the cam seals? And the middle maybe from the oil cooler seal? The whining noise comes only while accelerating.
Old Jun 11, 2017 | 10:36 AM
TimiK's Avatar
does it tighten the belt? :D
Old Jun 11, 2017 | 04:01 PM
The belt is tight enough 👍🏻
Old Jun 12, 2017 | 04:46 AM
I just found out the leak source. I think it is the oil sensor not the oil cooler o ring
Old Jun 13, 2017 | 07:09 AM
ISUBIEXI's Avatar
My timing belt made the car sound like it had a super charger when the belt was too tight. You should have some play in the belt, as in you should be able to push it with your finger and it should bend.
Balancer belt? Maybe its an issue with your balance shaft? Are you still running a balance belt?
You can check the distributor for OIL, maybe the bearing in the dist is going bad.
Old Jun 14, 2017 | 10:41 AM
beeza's Avatar
Usually they make a distinct bearing noise but
Check with an automotive stethoscope,$5 off ebay or a garden hose,to find where the whine is coming from.Not easy to pin point sometimes.
Old Jun 14, 2017 | 11:50 AM
Just to let you know guys problem solved. It was the oil pressure sensor leaking a lot and making the oil pressure drops. I had it replaced and now no more leaks no more whining noise 😁
Old Jun 14, 2017 | 08:30 PM
TimiK's Avatar
hope you got oem sensor there - I have bad experiences about sparepart sensors (other than o2)
Old Jun 15, 2017 | 03:33 AM
Yep I bought OEM. I was like that buying cheap stuff but I learned my lessons After I had it nicely lol 😂
MTBR27
Mar 24, 2014 03:39 AM
BAYxlude88
Dec 29, 2008 02:30 PM
ilikehonda
Oct 23, 2006 09:10 AM
vietintegboi
Oct 16, 2006 02:10 AM
motormanSR
Mar 15, 2005 02:46 PM
