2013/ EK Drag Build
Old Jan 15, 2017 | 05:34 PM
  #301
DA 4 Lyfe's Avatar
Default Re: 2013/ EK Drag Build
Originally Posted by locash
I don't post here much anymore, but I figured I would comment on this thread..
Currently using a single 3 port on this car, and you're probably not going to make 45+ psi on a 62mm . This car is on a PTE 6870 now..
For what its worth, my 62mm 8.6x car doesnt make that much boost at any event.
I don't necessarily plan on making 45+ psi. IMO I don't see the turbo making much more then 42psi before it starts to blow out hot air. Eventually ill get the PTE 6870 I mean 6270 My overall goal is to be able to have an extra amount of PWM cycle left over to use the quick spool and taper in boost if need be
Old Jan 16, 2017 | 08:42 AM
  #302
95dxsir2's Avatar
Congratulations on cracking 8's!!!!!!
Old Jan 16, 2017 | 12:36 PM
  #303
luck4rmkc's Avatar
Originally Posted by AZ_CIVIC
Thanks man, Joe was telling me you got the new gear set and the same turbo I am running. I think with that combo your going to be where I'm at. The strain gauge and the new turbo alone just knocked .6 tenths off my time this weekend. Oh and of course the guy behind the laptop LOL.
The guy behind the laptop is a crackpot! He puts unicorn pictures on my Motec layout and tells me it's his spirit animal!
Yeah new gear set for me with a slightly taller FD than yours, PTE6870 and some weight reduction for my little piggie this winter. What A/R exhaust housing are you using on your setup?
Old Jan 16, 2017 | 12:51 PM
  #304
AZ_CIVIC's Avatar
.96 and I'm also trying to get the car lighter as well. Had to start pulling all of the stuff out of the car. I basically had left everything in for FIS, so now trying to lighten things up.
Old Jan 18, 2017 | 05:24 AM
  #305
extremeracer's Avatar
So on Tuesday, I started prepping the car for webcam pro's, pulled the head off the car and got while I was cleaning everything up Joe and I went to pull the cam gears off my skunk2 pro 1's and got the first one off and Joe was tapping the other cam gear off when this happened.
So the last event after I made a pass I was cooling the motor down when I noticed the intake cam gear bolt was gone. I was happy because at some point in the pass the cam bolt backed out or something and I was happy the cam gear didn't come off. So before this event doubled checked the cam gear bolts and even had Joe put locktight on the bolts. During the event no problems but taking the cam gear off this happened, I'm think the reason the bolt may have backed out last event was because the cam cracked. Maybe not too bad but enough for the bolt to slip out, after this event with a little tapping on the cam gear it just broke the rest off. I was lucky LOL
Car looks great, I love black drag cars ! Had a Pro 1 cam break off similarly on our drag car whilst it was idling ! Luckily it happened on idle and didn't cause any damage before we shut it off due to a rough idle...
Old Jan 18, 2017 | 09:18 AM
  #306
AZ_CIVIC's Avatar
Yeah I was lucky as well, I'm glad the head is off and everything is being looked at. For my new cam setup I needed stiffer springs so those are being replaced and found out yesterday the retainers are pretty worn so those will be replaced. So I'm hoping I will be ready for IFO in February.
See if I can A. Get the car to run consistently in the 8's and B. Shoot for 8.7's LOL
Old Jan 19, 2017 | 09:40 AM
  #307
locash's Avatar
Your spirit animal is the Blunicorn, mine is not. I'm pretty sure you just like the horn.
Old Jan 19, 2017 | 10:24 AM
  #308
ssmrico's Avatar
wow nice congrats
Old Jan 19, 2017 | 11:14 AM
  #309
AZ_CIVIC's Avatar
Joe likes to leave messages on my AiM Cluster LOL
Originally Posted by ssmrico
wow nice congrats
Thanks man
Old Feb 5, 2017 | 07:17 AM
  #310
AZ_CIVIC's Avatar
Well after pulling the head, basically the entire valve train was replaced. Valves, valve springs, retainers, locks, and seals along with the new cams were installed and I finished putting the remainder of the car back together yesterday.
Old Feb 5, 2017 | 01:12 PM
  #311
hondatech8798's Avatar
Which cams are u running now may I wonder ?
Old Feb 5, 2017 | 02:28 PM
  #312
AZ_CIVIC's Avatar
Web cam pro's are rumbling in the car now. They sound like a beast.
Old Feb 6, 2017 | 10:26 AM
  #313
Let's see some vids
Old Feb 6, 2017 | 12:23 PM
  #314
ssmrico's Avatar
wow wow wow love it. I like that full distributor delete
Old Feb 6, 2017 | 12:28 PM
  #315
AZ_CIVIC's Avatar
Yeah that was removed when I changed over to Motec.
Old Feb 6, 2017 | 12:52 PM
  #316
ssmrico's Avatar
badass.ill be happy when I at least do the cop kit lol
Old Feb 6, 2017 | 01:01 PM
  #317
AZ_CIVIC's Avatar
Yeah I like the COP kit, you're on Hondata correct?
Old Feb 7, 2017 | 04:23 AM
  #318
ssmrico's Avatar
yeah I am. about to send it to upgrade to v3
Old Feb 7, 2017 | 08:24 AM
  #319
AZ_CIVIC's Avatar
Nice, I heard that Hondata is coming out with a Strain Gauge option. That will be a nice addition to have with Hondata.
Old Feb 7, 2017 | 08:30 AM
  #320
ssmrico's Avatar
mhmm interesting. Im outdated I just found out they went Bluetooth lol so I need to catch up
Old Feb 12, 2017 | 10:44 AM
  #321
AZ_CIVIC's Avatar
Old Feb 13, 2017 | 04:18 AM
  #322
ssmrico's Avatar
moving!!
Old Feb 13, 2017 | 06:29 AM
  #323
AZ_CIVIC's Avatar
moving!!
Yeah the 8.52 was Locash Racing's other 62mm race car driven by Aaron Teague. He set another world record with an 8.49 I think was the fastest yesterday.
It is crazy how fast that thing is going with a 62mm turbo.
Old Feb 13, 2017 | 07:55 AM
  #324
Hasport's Avatar
car is looking good as always
Old Feb 13, 2017 | 08:14 AM
  #325
AZ_CIVIC's Avatar
Thank you!!
