**OFFICIAL FORCED INDUCTION RANDOM CHAT THREAD**
Old Mar 22, 2016 | 09:18 PM
  #3551
2kdrift's Avatar
Default Re: **OFFICIAL FORCED INDUCTION RANDOM CHAT THREAD**
Originally Posted by allmtrb16ek4
Does anyone happen to know how to wire up a resistor box to Dsm injectors? 98spec itr motor inside 98 civic hatchback...idk if it matters but I'm running a jrsc also and since I'm on that subject should I even run the jrsc FMU? I have hondata
heres the link https://honda-tech.com/forced-induct...adband-517274/
all I had to do was google search it
dont use the fmu, fmu is a hack to raise your fuel pressure based on boost but its innacurate. you wouldnt use it with hondata any way. but toss the fmu and get tuned on hondata
Old Mar 22, 2016 | 09:20 PM
  #3552
2kdrift's Avatar
Originally Posted by kr3w108
I had a friend with a stock motor cobalt SS That made 450 on 19 psi with a log manifold . S256et is a pretty good turbo.
yea they are popular with cobalts do you know which housing he was using? 19 PSI seems to be its sweet spot seen a few builds that ended up at 19
im looking for about 400 give or take, I have the .55 A/R
Old Mar 22, 2016 | 10:35 PM
  #3553
kr3w108's Avatar
no idea. i know it did have a 3" exhaust tho.
Old Mar 22, 2016 | 11:30 PM
  #3554
allmtrb16ek4's Avatar
Wow bro thanks that is a gold mine and thanks for the tips on the FMU @s2kdrift
Old Mar 24, 2016 | 10:41 AM
  #3555
Schister66's Avatar
Man U FTW
anyone have experience running a BEP S256?
I love the S256 and used to push it really hard to anyone looking for a responsive, tank of a turbo that will make 450-550whp reliably.
The setup was a 9.8:1 forged, stock sleeve B18a with a GSR head. It was on an SLS Prototype manifold with 3" dp, exhaust and 2.5" charge piping.
On 16psi (wg pressure) - 385whp/285wtq on corn. I was having boost controller issues at the time and it spiked to 26psi once and untuned it made 502whp, so there's a lot left in the turbo. Soon after, i bought an 06 STi and sold the GSR to my buddy. He still has it - with the same setup and all. This summer we have plans to retune (since its been like 7 years) and try make 450-ish out of it on e85. All in all, i'd suggest the S256 if you're looking to make 400-500ish whp. The kicker is going to be the fuel you're using.
Old Mar 24, 2016 | 01:39 PM
  #3556
Stopsign32v's Avatar
Loved
What about the S252
Old Mar 25, 2016 | 12:30 PM
  #3557
2kdrift's Avatar
S252 is rated 50 HP lower so it should have faster spool with slightly less HP.
I actually have the B252, which is supposed to have the spool of the s252 (or faster) with the flow of a s256. Just cant find anyone that has actually ran it at least on a honda, only a guy was on D series that made 390. Seems to spool pretty quick, Ive heard of cobalts making 500 to the wheels so hopefully its all good. Still gotta get tuned, Im just replacing cap, rotor, coil OEM, and installing ATI pulley and cam gears
Old Mar 25, 2016 | 06:57 PM
  #3558
Loved
Do you have a link to your B252? Never heard of it
Edit: yikes, GTX price range
Old Mar 25, 2016 | 08:38 PM
  #3559
2kdrift's Avatar
Yep LOL
Old May 14, 2016 | 05:05 AM
  #3560
ls joker's Avatar
Loved
Sooo........
Ive been thinkin bout trying to sell my SI. Using that money towards a s2000 or a e46 m3. After lookin at the specs for the m3. ***** pretty badass. Individual throttle bodies, revs to 8k, weights bout 3500lbs. Diff can hold bout 350 or so pounds of torque. Cheaper in price over s2000. And the best thing, its a better suitable old man car for when i get older.
Old May 14, 2016 | 08:08 AM
  #3561
Geis's Avatar
Originally Posted by ls joker
Sooo........
**** man, it has itbs and is less than the s2k? What?
As far as suitability goes, space wise yes. Brand name and looks wise, debatable. Down here in Socal there are quite a few s2ks, and honestly the driver base is split pretty 50/50 from what I've seen. 50% are usually younger (asians) with nice tuned projects, and the other 50% is usually older white males. No shame in driving one when you're older
I'm assuming you will probably do some mods to either, so then I guess it comes down to the long terms goals and whatnot. F20c is hard to beat when boost though
Old May 14, 2016 | 08:11 AM
  #3562
Geis's Avatar
Ok but those e46s are pretty badass though too..
Old May 14, 2016 | 10:58 AM
  #3563
supersilverdc2's Avatar
what thermostat goes well on a 400-500 hp turbocharged car, is the OEM thermostat ok?
Lsvtec fully built
borg warner s360
mishimoto 3row radiator half size
E85
Old May 14, 2016 | 12:41 PM
  #3564
Geis's Avatar
Lsvtec fully built
borg warner s360
E85
OEM thermo is NOT ok...doesn't tell you that your engine is overheating until it's too late.
Old May 14, 2016 | 01:12 PM
  #3565
LightningTeg's Avatar
Community Builder
Old May 14, 2016 | 02:07 PM
  #3566
ls joker's Avatar
Loved
Lsvtec fully built
borg warner s360
E85
Oem thermos is fine. Thats what i run. And im over 400whp.
Old May 14, 2016 | 02:44 PM
  #3567
Geis's Avatar
??? Really?
Well ****, all the older Hondas I've been in have had kinda fucked thermos, albeit that's just from a few I've seen.
But hey, if they so go for it, and you have a properly functioning thermo go for it
Old May 14, 2016 | 03:31 PM
  #3568
2kdrift's Avatar
Sounds like your talking about the stock temp gauge...which is actually true. ECT sensor is far more accurate which you can read through hondata or whatever EMS you are using.
Thermostat, stock is best low temp thermostats do nothing
Old May 14, 2016 | 11:26 PM
  #3569
Tx was having a debate about my build, wanted a OEM, but someone said get low thermo and i was very skeptical
Old May 15, 2016 | 02:41 PM
  #3570
TheShodan's Avatar
Moderator
OEM is fine. I'm at 530whp on OEM thermostat. Geis might be thinking of the OEM Gauge needle used for water.
OEM has been fine for 20 years of turbocharging. Stick with that, and you'll be fine.
Old May 15, 2016 | 04:54 PM
  #3571
2kdrift's Avatar
all they do is put additional stress on bearings etc since it takes longer to warm up....Saw a thread on the hondata forum which stated
"whats the difference between a 60c thermo and a 70c once your vehicle is at operating temp?"
Old May 16, 2016 | 04:11 AM
  #3572
Community Builder
Stick to OEM. Every time ive used a none OEM tstat from Honda, I've had issues.
Old May 17, 2016 | 03:55 PM
  #3573
Geis's Avatar
Lsvtec fully built
borg warner s360
E85
Apologies for my misinformation
Old May 25, 2016 | 07:14 AM
  #3574
Community Builder
Got a random text to make some pulls yesterday lol. His 200 shot didn't fire so just a good video.
Old May 25, 2016 | 07:44 AM
  #3575
ls joker's Avatar
Loved
Lol, was that without brake boosting.
