98 civic - Fuse #44 blows when key is turned to on
Old Apr 23, 2016 | 01:02 PM
  #101
Former User's Avatar
Default Re: 98 civic - Fuse #44 blows when key is turned to on
Originally Posted by Fearz32
Okay there's only 12v on both wires with the coil installed.
12V is fine.
I removed and tested the coil and still reads at 0hms. I'm going to autozone to replace . Should i try to start it after replacing?
Yes
Originally Posted by RonJ
If the plugs, wires, cap, and rotor are also old, replace them as well.
Old Apr 23, 2016 | 01:39 PM
  #102
Fearz32's Avatar
12V is fine.
Yes
Hello Ron I changed the coil and still no start I'm getting code 8 now though.its the tdc sensor code.
Old Apr 23, 2016 | 02:44 PM
  #103
Fearz32's Avatar
12V is fine.
Yes
And also I think this coil also went bad I tested it before and now it's reading 0hms on A-B and 10k ohms on A-primary winding. I have 1 year warranty thought so it's good lol. Should I also take in the icm to test?
Old Apr 23, 2016 | 02:52 PM
  #104
Also, if you reset the ECU, does code 8 return?
Old Apr 23, 2016 | 02:54 PM
  #105
Fearz32's Avatar
I reset the ecu and code went away . Tried to start again,Code did not return. Checked for spark and there was none.
Old Apr 23, 2016 | 02:57 PM
  #106
^^^ Please respond.
Did you do the Ohm test on the coil prior to installing?
Return the coil for a replacement? Ohm test right out of the box prior to installing.
Old Apr 23, 2016 | 03:00 PM
  #107
Fearz32's Avatar
^^^ Please respond.
Yes I tested the coil prior to installing and it was fine. I cranked the car without the rotor does the rotor have to go back facing a certain wire way.
And wires cap and rotor are fine this distributor was running with the motor before the swap.
Old Apr 23, 2016 | 03:05 PM
  #108
Replace the plugs, wires, cap, and rotor if they are old. Otherwise, you will continue to blow coils.
In addition, never crank the engine with any plug wires unplugged. This too will blow the coil.
Old Apr 23, 2016 | 03:07 PM
  #109
Fearz32's Avatar
Alrighty will do the cap and rotor were replaced recently I will go get a new coil and wires.
Old Apr 23, 2016 | 03:09 PM
  #110
Install new plugs too if they are old.
Old Apr 23, 2016 | 03:12 PM
  #111
Also ask AutoZone to test the ICM.
Old Apr 23, 2016 | 06:49 PM
  #112
Fearz32's Avatar
Replaced icm and coil car started RPMs now work but car dies no engine codes. i started it again able to keep it alive by giving it slight throttle. If I don't give it throttle it will stall out. I will try to see if starting fluid helps it stay on tomorow.
Old Apr 23, 2016 | 09:45 PM
  #113
Drive the car around a bit. It's possible that the ECU just needs to relearn the idle setting.
You also may need to adjust the ignition timing.
Old Apr 23, 2016 | 09:55 PM
  #114
Fearz32's Avatar
I don't think it's possible to drive it its stumbles when I press the gass and won't go past 2.5k RPMs and I will adjust the timing tomorow .
Old Apr 23, 2016 | 10:06 PM
  #115
Make sure the plug wires are installed in the correct firing order on the distributor cap, and keep monitoring for CEL codes.
Besides the ICM and coil, what other ignition parts did you replace?
Old Apr 23, 2016 | 10:16 PM
  #116
Fearz32's Avatar
I also replaced the spark plugs. The wires and cap the previous owner did before he sold it to me they look in good condition.
Old Apr 23, 2016 | 10:19 PM
  #117
Properly gapped NGK plugs?
Do yourself a favor. Replace them. Buy Honda plug wires. A new aftermarket cap should be fine.
Is the rotor new?
Old Apr 23, 2016 | 10:43 PM
  #118
Fearz32's Avatar
Is the rotor new?
Well previous owner replaced them because the alternator was in a box in the trunk. And I bought gapped Bosch plugs . I will replace cap and rotor and wire tomorow in the am. I will also check the firing order.
Old Apr 24, 2016 | 07:43 AM
  #119
You should only use the NGK spark plugs recommended in the owner's manual.
Old Apr 24, 2016 | 08:02 AM
  #120
Fearz32's Avatar
Okay will these be okay to turn the car over? I'm kinda low on funds and just bought the cap and plugs . I won't be driving the car for another week so I will have money by then.
Old Apr 24, 2016 | 08:09 AM
  #121
You may want to wait. There's some risk of blowing the coil again if one of the maintenance components (e.g., wires) of the ignition system is bad. In addition, a misfiring engine is not good.
Old Apr 24, 2016 | 08:13 AM
  #122
Fearz32's Avatar
I have new wires and a new cap I bought this morning . I would not be able to replace the Bosch plugs I bought until Friday.
Old Apr 24, 2016 | 08:15 AM
  #123
New rotor?
Old Apr 24, 2016 | 08:17 AM
  #124
Fearz32's Avatar
New rotor?
Same rotor should I also pick one up? Current one seems fines ? No cracks on the current one. But I'll pick one up today also.
Old Apr 24, 2016 | 08:19 AM
  #125
Given the coil blowing issue, buy yourself the insurance policy (i.e., new rotor).
