93 Del Sol Si - Fuel Injector Rebuild/New vtec gaskets/PCV "mod" = Not Starting
Would retarding/advancing the timing cause that as well or not? The distributor is also missing a bolt, if that matters.
Should be fine to reuse.
The timing belt skips teeth on the cam or crank gear.
Nope.
Post pictures.
What causes the timing to be off in the first place?
It doesn't seem like it; it would be very minimal if it was. I believe most of that gunk is from the old leaking valve cover gasket. The last person to replace the gasket smothered it in grey atv which I think caused it to become severely leaky.
Are they a standard size or do I have to order it from a Honda parts website?
By the way, how hard will it be to get to the crankshaft pulley? Can it be done without removing the wheel? I don't have any extensions long enough to stick out from the wheel well.
What engine do you have?
See diagram I posted. Rotate crank pulley counterclockwise until the cam pulley is perfectly positioned at TDC1. At no time should you ever rotate the crank pulley clockwise. After cam pulley is set at TDC1, look down at the crank pulley to see if the lone white mark is perfectly aligned with the pointer on the lower timing belt cover.
Edit: It did not come loose, it just suddenly became easy to turn. The white mark on the crankshaft is off a little less than an inch to the left of the lower cover's pointer. I'll go take a picture real quick.
The actual engraving for the crankshaft mark is in the very front of the white paint. It's actually only off by 1/8th of an inch or so.
Timing looks good.
Time to compression test the cylinders.
Did you already verify that the plug wires and injector wires are installed in the correct firing order?
The injector wires should be correct (they're currently unplugged though). Is it possible that I could have fried the fuel injectors while testing them? If you look at the images in the original post, you should see the fuel injector wires. What I did was hook the negative clamp to the black and yellow wire's side of connector on the injector, and the positive clamp to the other wire's side. Then I proceeded to test them using the battery. Isn't the black and yellow the negative one?
Have you removed the fuel rail with the injectors, and then cranked the engine to see if all 4 injectors pulse fuel and are not stuck open?
The Yel/Blk wire should have battery voltage. The other wire that runs to the ECU supplies ground.
So what you are saying is that the black and yellow wires are the positive? Would it matter if I had switched the positive and negative around? I've heard that injectors aren't polarized so I don't know if they'd be fried or not.
I'm actually going to do another test on the injectors and if they are confirmed screwed up, then I guess I'll be getting new ones.
I did more testing on the fuel injectors by swapping them around, and it turns out the same two are still jetting out a constant stream of fuel. Which I believe the stream of fuel is not reaching the spark causing it to not fire and flood the cylinders at the same time.
So I guess two non-firing, flooded cylinders are causing it to not run correctly? And are fuel injectors fixable in this condition, or will I just have to get new ones?
Welp, I'll probably just get some new ones then. I'll update this thread with the outcome once I get and install them. Hopefully this will be the fix that makes this car running (good) again and assist whatever underlying problems it has relating to this and the smog problem.
