91-92 DA Integra OEM Taillights, OEM Manifold, OEM Spoiler, OEM Driver Mirror
Old Apr 9, 2016 | 04:38 AM
trm4life's Avatar
Default 91-92 DA Integra OEM Taillights, OEM Manifold, OEM Spoiler, OEM Driver Mirror
-I have a passenger and driver side (not matching, one from a 91 ls (clear) and one from a 92 GS) set of taillights. 2 door only! You'll need new seals. All wiring still attached. 65$ buys the pair.
-I have a driver side taillight from a 91 ls 4 door. Again, needs a new seal. 45$
-92 GS AUTOMATIC OEM manifold and downpipe (4-2-1 style!) Will work on manual if you have the downpipe, or add a flanged exhaust piece to bolt up to your cat. 80$
-OEM Driver side mirror (color code R-72p) from a 91 4 door (should fit any 90-93 teg) 35$
-OEM cruise control module (automatic only unless you know how to wire it up) 35$
-OEM OBD0 (from a 91 manual trans, ORIGINAL TEC!) Distributor! These are apparently hard to find, and far better than cheap aftermarket! Over 200,000 miles but as far as I know still good!
2 door OEM taillights
4 door OEM driver taillight
OEM 4-2-1 manifold
PR4 cruise control module
(I swapped into an OBD1 car, so I technically have no use for this but it can be wired if your willing to cut and solder)
Old Apr 14, 2016 | 07:37 AM
trm4life's Avatar
Default Re: 91-92 DA Integra OEM Taillights, OEM Manifold, OEM Spoiler, OEM Driver Mirror
These are still available!
I forgot to post a pic of the spoiler, but its hard to take a shot of something that blends into the background, I'll work on getting it up. The spoiler has damage on one thread anyway, needs resin or something to fill in corrosion around the bolt in the spoiler.
Old Apr 24, 2016 | 10:24 AM
trm4life's Avatar
All parts still available!
