b16 VTEC - should i go with oem or msd distributor cap
Old Mar 10, 2012 | 09:04 AM
BKJJ77's Avatar
Default b16 VTEC - should i go with oem or msd distributor cap
i need to replace my distributor cap and rotor
i have msd right now but i dont kknow which is better aftermarket or oem
Old Mar 10, 2012 | 09:10 AM
grumblemarc's Avatar
The Grumpiest
Default Re: b16 Dock Vtech
OEM. MSD is crap.
Old Mar 10, 2012 | 09:18 AM
BKJJ77's Avatar
ok thanks and i need new wires but i cant find oem ones are ngk wires good
Old Mar 10, 2012 | 09:39 AM
JuggerNaut-CTR's Avatar
Dock Vtech.....
Old Mar 10, 2012 | 09:59 AM
The Grumpiest
Originally Posted by JuggerNaut-CTR
Dock Vtech.....
Give it up. You know what he meant.
Old Mar 10, 2012 | 10:02 AM
True...and its not that hard
Old Mar 10, 2012 | 10:20 AM
BryanM.'s Avatar
Resident Gearhead
Yes they are great.
Years ago I had a set of Bosch wires that practically fell apart when I
pulled them out to do a spark plug change. Can't say I'll buy them again.
EDIT: Like Marc said, OEM wires are probably the best.
They are ~$70 shiped from Majestic.
Old Mar 10, 2012 | 11:30 AM
Former User's Avatar
Default Re: b16 VTEC - should i go with oem or msd distributor
Thread titles MUST summarize the tech problem so that members browsing titles can easily understand the problem without reading the post -- Title edited.
Old Mar 10, 2012 | 12:51 PM
BKJJ77's Avatar
i put dock vtech to grab attention
Old Mar 10, 2012 | 12:54 PM
Please only use clear concise titles that summarize the tech problem.
Old Mar 11, 2012 | 07:19 AM
Red_Army's Avatar
maybe you could organize all of your questions into one post too. everyday theres 2 or 3 new posts from you about mostly silly questions that could have been searched.
to the OP OEM. covered tons. asked yesterday too.
Old Mar 11, 2012 | 07:41 AM
BobbyRodriguez's Avatar
MSD!!!!!!! OEM is for rich kids
Old Mar 11, 2012 | 09:30 AM
NotAJDMFanBoy's Avatar
I think MSD uses richporter technologies distributors, but not certain.
OEM is superior, aftermarket ICMs are notorious for being faulty. You can use sensors from any B,D,H,F series distributor and there are two OEM brands for the ICM, Hitachi and NEC, all of them can be swapped around regardless of part number. Coils can swap as long as the post is in the right spot for your cap since they're all the same part number.
If the body is ruined itself, you can salvage the shaft and bearing assembly from other distributors, most use one stamped P06. I found these in D series, Integra LS and F series Accord distributors. And you can buy the seal for the bottom of the body of the distributor.
Some people don't want to mix distributors and motors, not wanting to cut off tabs or widen slots to make a different distributor work or put D series parts in a B series distributor. However, the screws pretty much just keep it from wiggling around or turning and there are cam sensors that use one bolt alone, so that should work. Also people run motors on different ecus than what was meant for them, but they work. The guts all physically fit in other bodies. The fact is it works. I'm not a professional mechanic, just someone who's been broke and resourceful and found that this works.
Old Mar 11, 2012 | 09:32 AM
A new distributor for my aunt's 1993 Integra was like $250 she said. There are aftermarket ones for other motors that cost more.
If you have a GSR or b16, you're looking at $500-600
Old Mar 11, 2012 | 09:47 AM
BKJJ77's Avatar
i dont need a distributor i need the cap..a moderator changed my title to distributor instead of distributor cap
Old Mar 11, 2012 | 10:00 AM
The Grumpiest
O.
E.
M.
Old Mar 11, 2012 | 10:20 AM
Default Re: b16 VTEC - should i go with oem or msd distributor cap
^Illustrates the importance of creating a good thread title from the start.
Title edited.
Old Mar 11, 2012 | 12:14 PM
yup, go with oem. Best quality and only a few bucks more than advance and such charge. Or check out Rock Auto, they have some decent quality stuff for decent prices.
RedGSR1994
Sep 19, 2006 07:53 PM
teletekman
Nov 13, 2005 08:40 AM
Kyle244R948
Jul 29, 2004 10:19 PM
BassBoy19
Apr 13, 2004 11:33 AM
SHystrdyGSRtdy
Feb 17, 2004 07:54 PM
