The Chronicles of my Sedan
Old Oct 21, 2010 | 08:15 AM
  #251
efjones9's Avatar
Default Re: The Chronicles of my Sedan
Originally Posted by -NA-aLL-thE-wAy-
It's relocated. I've got a PC680 under the dash.
ur good to go with the ek intake!
Old Oct 21, 2010 | 12:45 PM
  #252
96accordsir's Avatar
clean
Old Oct 22, 2010 | 05:57 PM
  #253
-NA-aLL-thE-wAy-'s Avatar
EFSS153
A HUGE thanks to Adam from www.weaksauce.org for hooking me up on the Nardi ****. I really appreciate his business. There couldn't be a better guy as far as I am concerned. A HUGE thanks to Trent for the drain bolt, 4-wire O2 and (possibly) intake, too.
Here's to good parts and good friends.
Old Oct 22, 2010 | 06:30 PM
  #254
TahitianGreen's Avatar
lulz
Old Oct 23, 2010 | 01:42 AM
  #255
DCRB's Avatar
as far as intakes go i'm using a 3" short ram from autozone with a k&n filter. the piping puts the filter right where the battery would be. filter was free from a buddies swap, piping was 40 bux.
Old Oct 23, 2010 | 06:23 AM
  #256
CivicSi95's Avatar
asimo!!!!
Old Oct 23, 2010 | 07:05 AM
  #257
19efSedan91's Avatar
ill tell ya this build is completely sick. keep up the good work and i only hope mine turns out half as nice as yours does
Old Oct 23, 2010 | 07:26 PM
  #258
sde780's Avatar
Nice, I just read this whole thread. Sick EF, sedan love!
Old Oct 23, 2010 | 10:33 PM
  #259
YAGYAGAN_JDM's Avatar
Nice work you've put into the sedan. In for more updates
Old Oct 24, 2010 | 08:40 AM
  #260
WhiteSlips's Avatar
We are working on it for a few hours today. There won't be much visual going on, but we should be closer to getting it running. I'll take as many pictures as I can so we can make this thread have some more to look at.
Old Oct 25, 2010 | 05:34 AM
  #261
EFSS153
Chris was right, we didn't get a lot done visually, but a lot of small things got done. Most of the vacuum lines are hooked up, the driver side wire tuck is complete, holes are drilled for the manual shifter mount, the ITR/EG6 intake setup is mounted, the fuse box is relocated and mostly hooked up, the 4-wire O2 got cleaned up with new heat shrink and installed, the hoses for the heater core are hooked up, new fuel filter is in and the lines are hooked up, fuel injectors are soaking and almost ready to go in, etc.
We still need to complete the passenger side wire tuck, hook up a couple more vacuum lines, hook up the fuel return line, extend the power for the battery relocation, etc. As soon as the dust boots arrive for the steering rack we can install that. Once that is in we can put all of the suspension back in, install the rear mount, install the steering column, install shifter assembly, etc.
Getting closer!
Old Oct 29, 2010 | 05:31 PM
  #262
EFSS153
Another big thank you to Adam from WEK SOS.
Old Oct 29, 2010 | 06:09 PM
  #263
EFSS153
Still a little more to do. I'm hoping the chassis is mobile by the end of the weekend.
Old Oct 29, 2010 | 06:22 PM
  #264
EFSS153
Old Oct 31, 2010 | 01:17 PM
  #265
EFSS153
I need a couple good OBD1 D series injectors.
Old Oct 31, 2010 | 01:34 PM
  #266
mitsubishiv5's Avatar
vtec doo
looks good man, white cars are flashy it will be a very fun car once you finish the auto to manual swap and get it running. take your time.
  #267
JDM-EK-B18C5's Avatar
Damn your EF sedan is ill. Your motor looks like it brand new.
Old Oct 31, 2010 | 08:14 PM
  #268
johnnychavo's Avatar
kinda where ima at right now..minus all the coolness of your car.and v tech
keep up the good work. i just did all the wiring. took me a day to mock it up cut soder and tuck
Old Oct 31, 2010 | 08:20 PM
  #269
TheSauceSpot's Avatar
Nice progress, Sick ****!
I just got an I4 too. hows that case.. Otterbox is protecting mine. thats all aluminum correct?
Old Oct 31, 2010 | 08:59 PM
  #270
BrayzieEF9's Avatar
Motor looks better than brand new.
Old Oct 31, 2010 | 09:22 PM
  #271
EFSS153
Yes, aluminum. I love it. Nothing else feels as good. Expensive, but worth it.
Old Nov 2, 2010 | 09:09 AM
  #272
EFSS153
Okay, I think I'm squared away on the Z6 injectors I needed. Another big thanks to Adam (redzcstandardhatch) and Darkload from ef-honda for helping me out.
I am confused on something else, though. I need some help. Virtually everything on the Rywire harness is plugged in except for a green plug labeled "fan" on the BACK side of the motor. It has a ground connector running out very close to it. The intake manifold did not come with a map sensor so I tried to plug in the green plug to the stock DPFI map sensor hoping the green plug was just mislabled, but it did not work. Can someone please help me with some clarification? I'm wondering if I need a newer map sensor or if I need to splice a different plug onto the harness that will plug into the OEM map sensor I have or maybe I'm just way off base.
Old Nov 2, 2010 | 09:33 AM
  #273
flatulantdeath's Avatar
Fan switch on the therostat housing maybe? A ground goes there as well. Maybe that's it?
Anyways, can't wait to see it done, definitely one of my favorite cars on here.
Old Nov 2, 2010 | 09:38 AM
  #274
EFSS153
That one is green, too, but it is already plugged in. I'll snap a pic tonight.
Old Nov 2, 2010 | 10:01 AM
  #275
I have a bone stock 94 ex that I can snap pics off of if you want. I just went and looked at it and I see that same plug used in like 6 or 7 different places.
Top
Follow Us
