► 1994-2001 (GEN 3) - All General information & specifications
Old Sep 26, 2008 | 03:02 PM
  #26
b18c1ej8's Avatar
Default Re: (sick_dc2)
awesome write up, saves me time looking around for specs
Old Oct 27, 2008 | 09:10 AM
  #27
sixtodc4's Avatar
Default Re: 1994-2001 (GEN 3) - All General information & specifications (Jimmy)
i couldnt find what i was looking for i hope u guys can help me out . i have a 2001 ls integra. Is that ecu im running an obd2B or is a obd2A. Thanks if u do respond.
Old Oct 27, 2008 | 03:32 PM
  #28
Dogginator's Avatar
Daisy... Daisy...
Default Re: 1994-2001 (sixtodc4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixtodc4 &raquo;</TD></TR><TR><TD CLASS="quote">i couldnt find what i was looking for i hope u guys can help me out . i have a 2001 ls integra. Is that ecu im running an obd2B or is a obd2A. Thanks if u do respond. </TD></TR></TABLE>
00-01 are OBDIIb (chip in key). 96-99 are OBDIIa. 94-95 are OBDI.
Old Nov 20, 2008 | 08:04 PM
  #29
mardoiii's Avatar
bump for sweet write up
Old Jan 1, 2009 | 10:35 AM
  #30
fireisbadx's Avatar
nice write up i have 1 ques. do 94-97 parts fit the 98-01?
Old Jan 1, 2009 | 12:36 PM
  #31
HONDRETTI's Avatar
yes
Old Jan 1, 2009 | 01:21 PM
  #32
4dooritr's Avatar
thank you..
this has got to be one of the better threads on H-T
Old Jan 1, 2009 | 01:51 PM
  #33
R81_DC2's Avatar
thanks!!
  #34
SlammedDC2teg's Avatar
Thanks for posting that up. This should be a sticky for noobs.
Old Jan 1, 2009 | 02:20 PM
  #35
HONDRETTI's Avatar
Default Re: (Kendall)
Originally Posted by Dogginator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">I'm posting a link to this thread in the FAQ for all future reference.</TD></TR></TABLE>
It's been there since at least 5/29/2008.
Old Jan 18, 2009 | 10:58 AM
  #36
jdmdc2boi12's Avatar
good info
Old Nov 17, 2009 | 02:52 PM
  #37
RetroSeven's Avatar
good to know since I plan to replace the RSX for Integra
Old Nov 17, 2009 | 05:35 PM
  #38
93ivtecDa9's Avatar
im running a 15.4 1/4 at 88 is that good for a 93 integra ls stock did a compression test 200,190,190,205 it has 231,000 miles on the car
Old Nov 17, 2009 | 06:58 PM
  #39
ILS_09's Avatar
x2 great info!!!
Old Nov 17, 2009 | 07:12 PM
  #40
GagnarTheUnruly's Avatar
Why isn't this sticky yet? on this being stickied.
Old Nov 17, 2009 | 09:28 PM
  #41
PaulMc's Avatar
Painfully Stupid
You should make the last year '01, not '00.
'97-'00 Integra Type R - B18C5 1797 10.6:1 195hp@8000RPM/130lb-ft@7500
'94-'00 Integra GS-R - B18C1 1797 10.0:1 170hp@7600RPM/128lb-ft@6200
'94-'00 Integra LS/RS/GS - B18B1 1834 9.2:1 142hp@6300RPM/127lb-ft@5200
The last year for all four trims listed above was 2001. (for USDM spec) And this information should deffinitly be stickied.
Old Apr 6, 2010 | 12:02 PM
  #42
95-db6-719's Avatar
Those compression test numbers are wrong on the B18c1, and also the numbers for the fuel pressure are wrong according to Mitchell on Demand, which is a car service program, that costs roughly 5 grand.
the numbers it states for a B18c1 for compression is 200 psi and a minimum of 135 psi
also the number is states for fuel pressure for a b18c1 is 40 psi.
Also just called Acura, and the technician said their spec for the dealer ship should be 135psi-199psi, with variation between cylinders being 28 psi.
please fix numbers, and double check all other specs posted.
Old Mar 3, 2011 | 12:39 PM
  #43
::ek-4::'s Avatar
This is an awesome thread and it was extremely helpful.
Old Jul 7, 2011 | 12:08 PM
  #44
PezoCon's Avatar
Default Re: ► 1994-2001 (GEN 3) - All General information & specifications
Garageplusstorage.com for an all Import car show this coming July 16, 2011! Being held at Garage Plus Storage in Spanaway, WA.
Old Jul 7, 2011 | 12:36 PM
  #45
PezoCon's Avatar
Old Jul 10, 2011 | 07:22 AM
  #46
ddbarlow's Avatar
Great Info, Thanks! 94 LS
Old Jul 20, 2011 | 11:39 PM
  #47
TEGGRAWW's Avatar
DOES ANY1 HAVE A TRUNK HATCH FOR A 95 INTEGRA OR KNO WHERE TO GET ONE FOR CHEAP???? A DRUNK DRIVER RECENTLY CRASHED INTO ME (N I WASNT EVEN IN THE KAR!) N SO I NEED ONE REAL BAD!!!SHE IS MY BABY N MEANS ALOT N I WANT TO BRING HER BACK TO LIFE BUT I KANT FIND ANY?..
PLZ LET ME KNO WHUTS UP BECAUSE I NEED ONE A.S.A.P
THX TO ALL U TEGRAWWS LOVERS
Old Jul 21, 2011 | 07:55 AM
  #48
96builtcoupe's Avatar
thats great info man stuff i never knew thanks. 90 Ls da9.
Old Jul 28, 2011 | 11:47 AM
  #49
hondatravis's Avatar
amazing, easy to acces info!
Old Jul 28, 2011 | 04:20 PM
  #50
tegpro's Avatar
bump
good info
