Quick question on choosing a alarm/remote start
Guest
Posts: n/a
Hey guys- I am looking to do a full out stealth install into my 94 Civic. With that being said, its time to look for a model. I have always been a DEI fan when I was a installer, and plan on going DEI- if not im going compustar. Here are my 2 questions-
I find it terribly annoying when someones phone rings in class. I dont want my pager beeping while im class, at work, or anything- Id much rather have it set on vibrate or something along those lines- Any current models have a vibrate mode??
I plan on definately using a 520t, but can it be used with a compustar, or is it DEI only?
From what I've read DEI>Compustar
Didn't compustar have some serious security issues? I believe some recent models fixed this... I don't know much on the issue. Someone with more knowledge should chime in.
Not aware of any pagers with a vibrate only mode.. anyways, the beeping is nothing like a cell going off. You think vibration alone is enough to effectively alert you?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unbreakable6161 »</TD></TR><TR><TD CLASS="quote">From what I've read DEI>Compustar
Not aware of any pagers with a vibrate only mode.. anyways, the beeping is nothing like a cell going off. You think vibration alone is enough to effectively alert you? </TD></TR></TABLE>
I think that it should be plenty- I mean its getting to the point where im changing my daily habbits for the car-
Isnt a car supposed to benefit you, not hurt you?
With that being said Im going to have to really look into this- hope to hear input from more
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> Compustar 2way remotes have vibration mode.
94</TD></TR></TABLE>
And thats why I would bear the children of FCM
With that being said, Im going to look at some Compustar products- Id prefer a compustar anyways because of the manual remote start feature, as well as the quality- Only issue I see is compatibility with a 520t - Will that pose any problems to me?
94</TD></TR></TABLE>And thats why I would bear the children of FCM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 »</TD></TR><TR><TD CLASS="quote">
Ew.
Ew.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">
Ew.
</TD></TR></TABLE>Well I don't know, if it's a she, and she is 5'2-3" blond, and good looking, I'm on my way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 »</TD></TR><TR><TD CLASS="quote">Only issue I see is compatibility with a 520t - Will that pose any problems to me?</TD></TR></TABLE> Although anything is possible, the backup batt. will not work, [normally wired] with any remote start/alarm system that uses the heavy gauge remote start power leads as power for the alarm, although it would work fine for the alarm, the first time you remotely start the car the backup batt. charge/trigger circuit would go into melt down, it is designed to handle the current of an alarm not starting and running a car, that goes for any brand of alarm/remote start that uses the same power lead for alarm and starter.
94
Ew.
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 »</TD></TR><TR><TD CLASS="quote">solutions?</TD></TR></TABLE> A relay on the power lead that supplies the power for the alarm, #30 to alarm/starter, #87a to power, #87 to backup batt. 12V+ output with jumper from #87 to #85, trigger output from backup batt. to #86 and alarms neg. trigger input, [hood pin, diode between relay and hood pin input].
Not positive, but it should work, power gets cut triggering the backup batt. neg.(-) trigger output, [connected to relays #86] the relay would energize, backup batt. 12V+ output is now connected to alarms power.
94
94
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote"> A relay on the power lead that supplies the power for the alarm, #30 to alarm/starter, #87a to power, #87 to backup batt. 12V+ output with jumper from #87 to #85, trigger output from backup batt. to #86 and alarms neg. trigger input, [hood pin, diode between relay and hood pin input].
94 </TD></TR></TABLE>
haha Thanks- Ill give it a try once i get some dang time off from school. Will try to do a DIY as best as I can
94 </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vestalfootball72 »</TD></TR><TR><TD CLASS="quote">
Guest
Posts: n/a
hm good info- I used to sell/install these things at CC but dont remember a thing about them
Install shouldnt be a issue tho- its like riding a bike
EDIT-
Just read the manual. It seems like its a silent mode for the siren on the alarm?
I am looking to silence the keyfob or at least put it into a vibrate mode
Install shouldnt be a issue tho- its like riding a bike EDIT-
