Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Wheel weights falling off!
Old Oct 14, 2002 | 02:28 PM
6ghatch's Avatar
Default Wheel weights falling off!
I remember reading about this before but can't seem to find the topic. I lost a couple of wheel weights at VIR this weekend. What can I use to help keep them on? Thanks.
My temporary solution, racers tape.
[Modified by 6ghatch, 6:29 PM 10/14/2002]
Old Oct 14, 2002 | 02:42 PM
Tyson's Avatar
Default Re: Wheel weights falling off! (6ghatch)
thats pretty much the only solution, other than making sure they are put on clean.
Old Oct 14, 2002 | 03:28 PM
GSpeedR's Avatar
Default Re: Wheel weights falling off! (Tyson)
Look at the weights before you leave the tire shop. I worked at Discount Tire Direct all summer, and I must say that fitment is not issue number one.
If there is any space between the weight and the lip, it may fall off (especially with hight temps of racing).
Edit: I just realized we're talking about weight tape. Some customers requested to have additional sealant applied on the weights. This probably works pretty well but they may never come off.
Old Oct 14, 2002 | 03:43 PM
civicrr's Avatar
Default Re: Wheel weights falling off! (GSpeedR)
remember to check the racers tape. it seems to want to lose its adhesive properties with high heat. reapplication is sometimes needed.
Old Oct 14, 2002 | 03:59 PM
XrcR6's Avatar
1) Make sure the weight adhesive is flush with the wheel, no gaps/air.
2) Then use some kind of silicone sealant around the edge of the weight to prevent contamination of the adhesive tape.
3) Then duct tape/racers tape on top of that. And change this every once in a while.
Not much after that, except more cooling to your brakes to keep the adhesive from melting.
Old Oct 14, 2002 | 08:48 PM
XR4racer's Avatar
Go to Lowe's or Home Depot and get some HVAC Foil Tape. I swear it works great... doesn't rot or melt off like duct tape.
Old Oct 15, 2002 | 05:33 AM
Doctor CorteZ's Avatar
Default Re: Wheel weights falling off! (XR4racer)
what Robert said....
Old Oct 15, 2002 | 05:47 AM
thecaptain's Avatar
The folks here in Raleigh that do my tires/ wheels (Rockside Tires off Hwy 401) put some sealant under the lip weights before they pound them onto the wheel. It works as I have never lost a weight after they do that. Also, if its a large amount of weight I have them use two weights instead of 1.
I've also used racer's tape to good effect but the foil tape sounds even better!
BLUE EH3
Dec 29, 2006 11:17 PM
wfocrx
Jul 11, 2006 12:56 PM
todaCspec
Jun 4, 2006 02:51 AM
P@@RB@Y
Apr 30, 2006 05:30 PM
ViZ
Jan 3, 2004 08:47 PM
