Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
wheel spacers?
Old Jul 2, 2003 | 01:57 PM
B16b2b's Avatar
Default wheel spacers?
when should you consider using them. i have the speedmaster 15x6.5's (40mm offset) on my 96 hatch. when i turn the wheel almost to full lock, and put a lot of load on the suspension, i scrape the tire on the inside front of the frame......i never had this problem with a 38mm offset wheel.
can you run a 2mm wheel spacer without upgrading to longer wheel studs? what is the general rule on how much thread engagement is mandatory for safety?
BTW, i just put on some Azenis. i know they will be worse than my pirelli p700's have been. thanks.
Old Jul 2, 2003 | 05:11 PM
CivicSiRacer's Avatar
Default Re: wheel spacers? (B16b2b)
Most guys say the safest is 7-8 FULL turns of your lugs. I have a 3mm spacer and I get 8 turns.
Old Jul 3, 2003 | 06:12 AM
rambler's Avatar
New User
Default Re: wheel spacers? (CivicSiRacer)
I have yet to see any 2mm spacers... about the smallest I have seen is 3mm.
If you are interested I have an extra set that I have no need for. Hit me up on email or PM if you are interested.
Nash
a71rambler@hotmail.com
Old Jul 3, 2003 | 12:19 PM
B16b2b's Avatar
CivicSIRacer....does that mean 99+ si? anyways, would i then have problems with rubbing on the fender if i use as much as a 3mm spacer? what wheel tire combo are you running?
Old Jul 6, 2003 | 05:23 PM
B16b2b's Avatar
not interesting i know, but i'd appreciate any help....hasn't anyone else come across the same problem on the autoX circuit?
Old Jul 6, 2003 | 06:44 PM
chad's Avatar
Moderator
hey ford......5mm spacers on 99 si hubs, 92 cx hubs.....no rubbing .....probably 4-5 turns on the studs with the nuts with antiseize.....NO PROBLEMS!!! i just rolled my front fenders....
blackk20dc5
Feb 5, 2009 01:44 PM
Ponyboy
Apr 15, 2007 12:39 PM
steebypue
Apr 20, 2003 08:53 PM
Mike_C
19
Jul 10, 2002 03:34 AM
