Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Road Racing / Autocross & Time Attack (https://honda-tech.com/forums/road-racing-autocross-time-attack-19/)
-   -   TRM wheels shakedown (https://honda-tech.com/forums/road-racing-autocross-time-attack-19/trm-wheels-shakedown-2954107/)
SleeperGSR Jul 3, 2011 03:10 PM
So i drive a 96 gsr lightly moded for track days. Switched from the OZ supertourismo wrc 16'' to a TRM (tire rack motorsports)C1 15''. I was worried about the switch and going to a smaller tire, but man are they light. The steering and feed back is great. Not been out on the track yet but just around the neighborhood it was great. If you are looking for a light rim, check these out. I don't know how durable they will be i will update after i get to a track.
spAdam Jul 4, 2011 06:29 AM
Re: TRM wheels shakedown
I've been eyeballing these wheels for a little bit myself. The price is definitely right for a budget auto-x setup. Unfortunately, tire rack makes it hard to get any actual info about them without selecting a vehicle. Is there a chart of available sizes/bolt patterns out there anywhere?
The Destroyer Jul 4, 2011 07:18 AM
C1
BMW E30
15x7 +25
15x8 +20
Civic/Integra
15x7 +42
Miata (not C1M)
15x7.5 +42
spAdam Jul 4, 2011 07:35 AM
That 15x7.5 is real interesting...
Natural Aspirations Jul 5, 2011 01:37 PM
http://i39.photobucket.com/albums/e1...c/1c5f757b.jpg
15x8 +20
spAdam Jul 5, 2011 03:11 PM
Beefy. Those are offset a bit lower than I'm willing to go though. Planning on rolling/pulling?
.Manny. Jul 5, 2011 03:19 PM
Holy shit those are fat! Tire size?
I thought my 949s were fatties! gawdamm
The Destroyer Jul 5, 2011 03:28 PM
Those are 205 XS's. They do look good though. I wish all the wheels had that same concavity.
Natural Aspirations Jul 5, 2011 03:45 PM
The font was fine, hits the liner a bit.
The rear had to be raised up and some negative camber (-2.5Deg) and still will rub on the highway on big dips
FlewByU352 Jul 5, 2011 04:31 PM
maybe I am computer illiterate but I can't seem to find a price or available sizes for them other than 15" or 16"
Natural Aspirations Jul 5, 2011 04:53 PM
Afaik they only cone in 15&16 in 4x100
The Destroyer Jul 5, 2011 05:05 PM
They only come in 15" and the prices will be 89-99 ea.
FlewByU352 Jul 5, 2011 09:01 PM
That is insanely cheap for a wheel that light and that good looking! **** Rota Slips lol. What off sets though? I would love a 15x8 +30 but I'd settle for a 15x7 +40.
Gustav129 Jul 5, 2011 09:39 PM
Looking good! I'd like to see how well they hold up.
dbang003 Jul 6, 2011 03:33 AM
i checked out the 15x7.5 and then searched for a 1995 miata. they're also showing a 15x9 +36.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
different model wheel, but i thought all the wide wheels were only available in low offset.
Has anyone used the TRM wheels that were made for the Miatas? i thought i read somewhere that the center bore needed to be opened up to fit Hondas.
-Drew
E-AT_me Jul 6, 2011 03:40 AM
C1M is hub centric for the miata, so you would need to bore out to fit. it is also slightly heavier at 13.1 lbs or so, that way they can be used for Spec Miata classes.
cletus11 Jul 6, 2011 07:35 AM
-Drew
I have a set on order. When they come in, I will post some pictures.
Cynical 1 Jul 6, 2011 12:40 PM
i have them in the 15x7, et30 fitment for the spec miata. -
yes, you have to machine a bit out of the center bore to fit them on a honda.
however, they fit great, and are fairly light.
have almost 10k miles on them, with some track time, and they are holding up great...
tires are 195/50/15 Dunlop Direzza DZ101's.
https://fbcdn-sphotos-a.akamaihd.net..._6770303_n.jpg
https://fbcdn-sphotos-a.akamaihd.net..._4840386_n.jpg
The Destroyer Jul 6, 2011 01:53 PM
Hard to tell, are those 205 Star Specs? They probably fit better that the +20, but the +20's look so much better with the concave faces.
spAdam Jul 6, 2011 03:44 PM
Agreed, but man +30 fitment is just right!
RED_90TEG Jul 6, 2011 06:31 PM
is the 15x8 actually functional at the track with out ripping ur tires apart? with the 20 offset? and im talking about hard driving not panzy shit
E-AT_me Jul 7, 2011 03:28 AM
Originally Posted by Cynical 1 (Post 45590841)
i have them in the 15x8, et30 fitment for the spec miata.
if they were for a spec miata, they'd be 15x7...
and Red 90teg, what do you mean by ripping tires apart? that doesn't make sense...
dbang003 Jul 7, 2011 07:50 AM
Anyone running 225 width tires (street or slick) on the 8"? Seems like I always see 205, but I'm guessing that's because there's better tire selection.
The post about destroying tires might be in reference to the aggressive camber, etc needed to fit the wide wheels.
-Drew
FlewByU352 Jul 7, 2011 08:07 AM
Running a 205 on a 8" wide wheel is totally pointless. I'm running a 205 on a 16x7 wheel and if I could have gotten a 215 in that tire with a 40 or 45 sidewall I would have put it on the 7" wide wheel. 215 is rather an odd size for tire manufactures though and to run a 225 on an 8" wheel I am almost positive you need a +30 or less offset to clear the suspension components. But again getting a wheel an inch wider if you're not going to take advantage of a wider tire is just added weight. I think a 205 would be slightly stretched on a 8" wide wheel.
The Destroyer Jul 7, 2011 08:39 AM
Kumho XS comes in a 215/45/16.
As for the comment about chewing up tires, id say im almost positive it was in reference to fender contact and the tires getting chewed up.
