Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Time attack wheel set up
Old Nov 15, 2008 | 11:19 AM
Tarmac Junkie's Avatar
Default Time attack wheel set up
I know 16x7 wheels will fit on a DA integra, edo runs them on his hc car. I was wondering if anybody has tried fitting a 16x8 wheel on a da integra without it rubbing? The offset I found for 16x8 wheels was 20. Would this rub on the outside of the fenders and qp? Any help is greatly appreciated.
Old Nov 15, 2008 | 01:32 PM
.:Made in OC:.'s Avatar
Default Re: Time attack wheel set up (Tarmac Junkie)
16x8 +20 is going to be a very hard fit outwith fender flares. Edo runs a 16x7 with a 245/45/16 Ra1. Not sure on the offset but nothing near +20. I think he's running either +35 or +42 on his 5Zigens but with neg 5 camber.
Modified by .:Made in OC:. at 3:48 PM 11/15/2008
Old Nov 15, 2008 | 03:14 PM
Targa250R's Avatar
be professional
Absolutely yes.
I've run 13x8" wheels with a +25mm offset and 225/50-13 tires (21.9" OD) on my EFs, and the fenders would cut into the tires with the stock camber curve. You aren't going to fare any better with 16x8s and any available tire on a DA without using camber adjusters to dial in a massive amount of static negative camber up front, and/or some moderate fender massaging.
Old Nov 15, 2008 | 11:07 PM
Default Re: Time attack wheel set up (.:Made in OC:.)
Thanks guys. I know what im going to run now...
Old Nov 19, 2008 | 08:48 AM
RSZero1's Avatar
If you are really set on running the 16x8 look at 949racing.com UL wheels, they have a x8 wheel that would work and even advise what you would need to do (tire size and rolling of fender, if needed) to accomodate the wheels.
They're inexpensive and cast and IIRC, decent weight for the size.
Old Nov 19, 2008 | 03:29 PM
kay_animation's Avatar
A little hard finding a set since they are in the middle of remaking the wheel. Supposed to release sometime in February. But if you can find some shops that still have them in stock, go for it
JsSIR
May 10, 2014 04:07 AM
Low and no vtec
Aug 29, 2013 07:12 PM
socalblueg
Aug 16, 2011 07:32 AM
evosix
May 25, 2009 12:30 PM
the all out kid
Suspension & Brakes
Jan 31, 2009 10:07 AM
