Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Tech Help: Wiring Ignition Switch/Start Button
Old Jan 5, 2003 | 06:21 PM
Ausmith's Avatar
Default Tech Help: Wiring Ignition Switch/Start Button
Hi gang,
I'm posting in this forum becuase I felt I would have a better response from the road racers than I might in the general tech forum.
I'm in the process of building a D Mod / SPU Civic hatchback. I will be using a custom aluminum dash with some very basic insturments. I have "gutted" all of the wire harnesses - wow there isn't much left. I only have one question and it is related to the ignition switch/start button.
I'll be using the following Longacre panel:
Now to my inquiry. On the stock ingnition switch (key block) there is a very small switch that has two blue/white wires. There is no mention of these wires in the service manual. One wire runs to the ecu. Is this some sort of anti-theft device? Do these wires need to be retained?
thanks in advance
Ausmith
[Modified by Ausmith, 3:22 AM 1/6/2003]
Old Jan 5, 2003 | 07:31 PM
sgT's Avatar
sgT
Default Re: Tech Help: Wiring Ignition Switch/Start Button (Ausmith)
all you really gotta do is run the momentary starter switch to the starter solenoid
and to the ecu. maybe not even to the ecu depending on how you wired it up.
Old Jan 11, 2003 | 03:52 AM
Want2race's Avatar
Default Re: Tech Help: Wiring Ignition Switch/Start Button (sgT)
I wired mine myself.. It was pretty easy actually.. I just cut the wires from teh start switch and splced them to the panel! Really easy!!
Old Jan 12, 2003 | 10:46 PM
Tyson's Avatar
are you talking about the key in buzzer sensor? in a small little black box thats attuched underneath the ignition assembly.
Old Jan 13, 2003 | 09:44 AM
project_mercy's Avatar
Default Re: Tech Help: Wiring Ignition Switch/Start Button (Tyson)
Bingo.
Old Jan 13, 2003 | 10:41 AM
AdamITR's Avatar
Default Re: Tech Help: Wiring Ignition Switch/Start Button (project_mercy)
Nice choice I still have to use the key in the car though ... damn immobilizer.
[Modified by AdamITR, 2:42 PM 1/13/2003]
Old Jan 15, 2003 | 09:49 AM
Ausmith's Avatar
Bingo.
LOL - are you serious? I couldn't trace that thing on the diagrams to save my life. They totally omitted it.... Problem solved!
Old Jan 15, 2003 | 10:18 AM
StageOne's Avatar
Default Re: Tech Help: Wiring Ignition Switch/Start Button (AdamITR)
That has to be one of the cleanest/nicest looking race interiors that I have seen
Old Jan 15, 2003 | 10:55 AM
Want2race's Avatar
Default Re: Tech Help: Wiring Ignition Switch/Start Button (StageOne)
http://216.227.34.77/racecar/howto
Its called ignition or something like that
spoolin-4
Nov 15, 2011 06:10 PM
speedd2286
Aug 23, 2005 02:19 PM
ActiveAero
Oct 10, 2004 10:54 PM
Ham'ed Hatch
Audio / Security / Video
22
Jul 29, 2002 07:15 AM
