Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
spherical compliance bushing?
Old Oct 30, 2007 | 04:59 PM
RyanR's Avatar
Default spherical compliance bushing?
with all this talk about spherical LCA bearings, anyone know of a source for spherical compliance bushings for a EG/DC application?
Old Oct 30, 2007 | 07:24 PM
slammed_93_hatch's Avatar
Default Re: spherical compliance bushing? (RyanR)
i made one, sold the only set i made.
No one else was really making them. But i decided not to go ahead and produce the ones i made because people didn't want to pay for them.
I have another set that just needs to get pressed together, but that is for my car.
Old Oct 30, 2007 | 07:32 PM
BrianZ's Avatar
Default Re: spherical compliance bushing? (slammed_93_hatch)
I would buy somthing like that
Old Oct 30, 2007 | 09:33 PM
Default Re: spherical compliance bushing? (BrianZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrianZ &raquo;</TD></TR><TR><TD CLASS="quote">I would buy somthing like that </TD></TR></TABLE>
I have thought about starting it up again.
Price would be some were around $1000 for a full set. That includes front LCA R+L, front compliance R+L and rear LCA too.
This includes everything ready to install into your car, you just have to send me an unbent set of everything, (core charge). This includes Aurora MIL spec bearings.
Old Oct 30, 2007 | 10:19 PM
RyanR's Avatar
good to know. but in the mean time, does anyone know of a company currently producing spherical compliance bushings?
Old Oct 30, 2007 | 11:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanR &raquo;</TD></TR><TR><TD CLASS="quote">good to know. but in the mean time, does anyone know of a company currently producing spherical compliance bushings?</TD></TR></TABLE>
no, I guess it was clear in my first post. One other person made himself a set, and bought my set. Those are the only two sets i have ever even seen.
Old Oct 31, 2007 | 06:20 AM
IT GUY's Avatar
Are you guys talking about something like this maybe?
http://www.progressauto.com/store/products_new.php
I've got MFactory stuff in the rear and had been looking for spherical bearings to replace the bushings in the front and stumbled across these.
Old Oct 31, 2007 | 09:38 AM
nscirocco's Avatar
Default Re: spherical compliance bushing? (IT GUY)
i made a set for my racecar as well using opposed angular spherical bearings
https://honda-tech.com/zerothread?id=1910744
ran them this season with no problems
Old Nov 1, 2007 | 04:30 AM
98SpecR's Avatar
Default Re: spherical compliance bushing? (nscirocco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nscirocco &raquo;</TD></TR><TR><TD CLASS="quote">i made a set for my racecar as well using opposed angular spherical bearings
ran them this season with no problems</TD></TR></TABLE>
any plans on making more?
Old Nov 1, 2007 | 07:16 AM
nscirocco's Avatar
Default Re: spherical compliance bushing? (98SpecR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98SpecR &raquo;</TD></TR><TR><TD CLASS="quote">any plans on making more?</TD></TR></TABLE>
not really .. was all machined by hand, just takes too long to do (and the cost on the bearings alone was ~250$)
Old Nov 17, 2007 | 09:13 PM
Renegade's Avatar
I've got UCA rod ends
https://honda-tech.com/zerothread?id=2125669
and made these a while back for the Front LCA
https://honda-tech.com/zerothread?id=1365738
Been running the LCA ones for well over a year with no problems and UCA rod ends for since early this year
Old Nov 17, 2007 | 10:45 PM
eg6vtec1's Avatar
This is Brian with PCI, I make a full bronze bushing kit. I have found this to be much better than sphericals. Also much cheaper and if you ever have to replace the bushings there only a couple of dollars each. They cover every bushing in the front, they can be installed to increase caster up to 2.5 deg. They should be priced around $300 for the full set or can be bought just the LCA or UCA
here is a picture of one of the bushings, its a steel sleeve black zinc, with bronze bushing.I made a few sets awile ago for testing, and so far every things looking good there holding up really well, so i should be going into production very soon.
Old Nov 18, 2007 | 11:58 PM
Default Re: (eg6vtec1)
brian i don't know how bronce bushing work, it doesn't look like it allows and articulation
Old Nov 20, 2007 | 07:12 PM
eg6vtec1's Avatar
Default Re: (slammed_93_hatch)
It doesn't need it, once you install them with just the arms and knuckles bolted up the suspension travels up and down freely with no binding what so ever.
Old Nov 20, 2007 | 08:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6vtec1 &raquo;</TD></TR><TR><TD CLASS="quote">It doesn't need it, once you install them with just the arms and knuckles bolted up the suspension travels up and down freely with no binding what so ever.
hmm i was under the impression that the compliance and LCA mount weren't in the same plane.
Old Nov 21, 2007 | 07:31 AM
nscirocco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
hmm i was under the impression that the compliance and LCA mount weren't in the same plane.</TD></TR></TABLE>
ya, they are .. the way i did it only allows rotation around the lca&lt;-&gt;compliance axis as well and it moves freely
Old Nov 21, 2007 | 08:09 AM
dyingwish's Avatar
Default Re: (nscirocco)
Does this bronze bushing make the front end feel "loose and rattly"? Some solid UCA / spherical setups feel like that. Just curious.
Old Nov 26, 2007 | 12:43 PM
eg6vtec1's Avatar
Default Re: (dyingwish)
only if there is play, but once they are installed thier pretty tight
Old Nov 26, 2007 | 01:59 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6vtec1 &raquo;</TD></TR><TR><TD CLASS="quote">This is Brian with PCI, I make a full bronze bushing kit. I have found this to be much better than sphericals. Also much cheaper and if you ever have to replace the bushings there only a couple of dollars each. They cover every bushing in the front, they can be installed to increase caster up to 2.5 deg. They should be priced around $300 for the full set or can be bought just the LCA or UCA
Curious how the caster adjustment is done. Any more details?
Old Nov 27, 2007 | 06:17 AM
descartesfool's Avatar
Default Re: (TunerN00b)
I had a set of Orijin bushings for the front UCA and a spherical for the LCA inner pivot. I found there was a lot of binding in the UCA bushings so I got a set of sphericals put into the OEM UCA mounts by KingMotorsports. They are very nice and eliminated all of the binding with the Orijin's I had. When I asked if KingMotorsports would make a set of sphericals for the LCA, they said that they had had too many of their race cars suffer from frame tear-out where the LCA bushings bolt into the frame. I have not had any issues with my Orijin LCA sphericals, but they have a blue plastic type of spacers, which is a little less hard core than a full spherical LCA bushing like ProgressAuto sells. Anyone know of this frame tear-out issue mentioned by KingMotorsports?
Old Nov 27, 2007 | 06:48 AM
TPB's Avatar
TPB
Default Re: (descartesfool)
Funny you should mention the frame tear-out due to lca SB's being used. I actually encountered this very problem two years ago with my dc2. Both holes in my lower subframe opened considerably and at a rapid pace (after about 3 race weekends).
I didn't notice until the holes had enlarged considerably but my car would dart from one side of the track to the other at speed... not a good feeling going up the Andretti Straight at Mosport in the wet
Old Nov 27, 2007 | 06:53 AM
WWDTrackRacer's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by descartesfool &raquo;</TD></TR><TR><TD CLASS="quote">I had a set of Orijin bushings for the front UCA and a spherical for the LCA inner pivot. I found there was a lot of binding in the UCA bushings so I got a set of sphericals put into the OEM UCA mounts by KingMotorsports. </TD></TR></TABLE>
How did you detect the UCA bushings were binding? I put ES ones on there and moved the arm through the travel range, and it seemed to move without any problems. Just curious.
Old Nov 27, 2007 | 07:18 AM
Right Tighty's Avatar
* B A N N E D *
Old Nov 27, 2007 | 07:39 AM
577HondaPrelude's Avatar
Default Re: (WWDTrackRacer)
Hey guys. I have made a prototype of a spherical bearing kit for the compliance bushings for the 6th gen civics. Here are some pictures. So far the tests have been great (no binding and zero unwanted play after several race weekends). I'm currently working with my machine shop to see if we can get about 10 sets of these made at a decent price. Here are some pictures of the prototype.
Also I have several spherical bearing LCA kits in stock for Civics, Integras, Preludes and Accords See link below if interested.
http://www.mckinneyraceworks.c...21_33
I hope to have the civic compliance bushings out soon, and I plan to get a set out for the integras soon after.
Old Nov 27, 2007 | 09:16 AM
Default Re: (577HondaPrelude)
Im not so sure those would be legal for h2-h4. Maybe H1, but as i understood it you have to replace the bushing and not the part that holds the bushing.
