Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Roll cage question
Old Mar 4, 2004 | 10:35 PM
Sport_Injected's Avatar
Default Roll cage question
itd like to make my street car/ auto x car as safe as possible so id like to add some harnesses which in turn means i must add a rollbar. Are theres any rollbars out that would allow me to keep my rear seats?
Old Mar 5, 2004 | 01:58 AM
jc836's Avatar
Default Re: Roll cage question (Sport_Injected)
IMO - Yes and no. It can depend on the car as much as the design of the roll bar/cage. Generally, you will sacrifice the rear seats in cars that are 2 door/2 seat or 2+2 types. I do not recommend the use of removable harness bars and the SCCA and NASA design specs are such that it is not really practical. One can use a bolt-in 4 point bar with the harness bar welded on to it and if need be take it out as needed. Good luck with a solution that works for you.
Old Mar 5, 2004 | 04:00 AM
Knestis's Avatar
Default Re: Roll cage question (jc836)
The question is, "as safe as possible" for what? If you are talking about driving on the street, I tend to believe that anything that you do will likely compromise safety.
Rollcages, harnesses, racing seats, helmets, window nets, and driver gear have evolved to work as a system on the race track. It is a very different environment and a very different set of threats.
K
Old Mar 5, 2004 | 04:21 AM
granracing's Avatar
A roll bar for auto x really isn't worth it. If you go to a autocross and are worried about safety, you're doing it with the wrong club.
And if you put a roll bar in and keep it in, why keep the back seats in? You won't have a passenger in the rear with a roll bar in anyways.
If you were doing HPDEs, there could be value in a roll bar. (Basically restating what Knestis said)
Old Mar 5, 2004 | 05:48 AM
Crack Monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sport_Injected &raquo;</TD></TR><TR><TD CLASS="quote">itd like to make my street car/ auto x car as safe as possible so id like to add some harnesses which in turn means i must add a rollbar. Are theres any rollbars out that would allow me to keep my rear seats? </TD></TR></TABLE>
Keep rear seats in place? Yes.
Use them for humans? No.
steronz
18
Sep 7, 2008 03:30 PM
iheartktwenties
10
Nov 18, 2007 11:54 AM
Boilermaker1
Sep 17, 2007 03:17 PM
divingcorners
May 31, 2006 11:06 PM
R.S.
24
Apr 6, 2004 08:06 AM
