Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Replace brakes before or after track session?
Old Jul 21, 2004 | 07:21 AM
cruzersi99's Avatar
Default Replace brakes before or after track session?
I may be heading to the Streets of Willow Springs at the end of the month.
My stock brakes and rotors have 60k daily driver miles. Should I replace the brakes now or after?
Old Jul 21, 2004 | 07:31 AM
Mike_C's Avatar
Do they need to be replaced?
Rotors? Might be fine, depends on grooves and/or cracking.
Pads? Probably need better than stock for the track.
Fluid? Same as pads.
Old Jul 21, 2004 | 09:09 AM
jdmjunky's Avatar
Default Re: Replace brakes before or after track session? (cruzersi00)
both
Old Jul 21, 2004 | 09:39 AM
rice r0cket's Avatar
Default Re: Replace brakes before or after track session? (jdmjunky)
Would you like the additional margin of safety on the track or after, when you're on the street?
Old Jul 21, 2004 | 11:10 AM
emwavey's Avatar
Replace now. And if there's anything left on the (old) pads, bring them with you just in case.
-dave, who has burnt through a set of pads that seemed like they had plently of "meat" left.
8)
Old Jul 21, 2004 | 11:24 AM
JoelG's Avatar
Default Re: Replace brakes before or after track session? (emwavey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emwavey &raquo;</TD></TR><TR><TD CLASS="quote">Replace now. And if there's anything left on the (old) pads, bring them with you just in case. </TD></TR></TABLE>
that is a really good plan. if all goes well you wont have to jack around with the car during your school, which is good, because you need to be concentrating on driving. if things dont go so well and you burn up your new pads you have something to get home on.
Old Jul 21, 2004 | 12:18 PM
Knestis's Avatar
If the rotors are in good shape, source yourself some aftermarket pads appropriate for track use and put them in before you go. Bleed the brakes, have fun, and when you're done, put your stock pads back in for the street.
Try our friends at Cobalt Friction - http://cobaltfriction.com - they can give you answers on pads.
K
Old Jul 21, 2004 | 02:40 PM
Weston's Avatar
Generic or OEM pads will perform like crap, overheat easily, possibly catch on fire (I have first hand experience), and you can go through an entire front set in one track day. They would also "warp" the rotors every time on me. That was all long ago and now I look back and realize how silly it was. There is absolutely no substitute for good pads on a road course. No amount of ducting or oversized rotors will even compare.
In my experience, Cobalt Spec-B's make really nice dedicated track pads. Big thumbs up from me. Excellent grip, good resistance to heat, and long life; it blows every "performance" street/track pad out of the water. The price seems high at first, but the number of laps you can get out of them makes them cheap. Just clean your wheels and car off after using them, otherwise the crap will attach itself to the wheels and paint and you'll have to use clay bar to get it all off. (or you can be a dumbass and wet sand it like I did, then have to use all kinds of polish to fix the clear coat )
Old Jul 21, 2004 | 10:00 PM
JDM SLICK's Avatar
What about the EBC greenstuff pads? I run them on my daily driver. Are they sufficient enough for a weekend track car?
What are you thoughts on them?
Old Jul 21, 2004 | 11:38 PM
TimeRacer's Avatar
Default Re: (JDM ***)
Greenstuff or any EBC is utter crap. Not worthy of track, and actually much worse than OEM in my opinion overall.
Old Jul 22, 2004 | 07:01 AM
Safir's Avatar
If there is any question in your mind wether they will be O.K. or not, service them before the track day - you do not want a failure at the track and things wear MUCH faster than you expect out there.
Old Jul 22, 2004 | 10:21 AM
Crazydave's Avatar
Default Re: Replace brakes before or after track session? (Safir)
I used to have a set of street rotors and pads that I used daily driving, to get me to and from the track.
I then had track rotors and pads..
If those got destroyed, my track day was over, and I was still able to get home on my street set
longuyen88
Suspension & Brakes
11
Aug 18, 2005 11:20 AM
GSpeedR
12
Apr 6, 2004 09:03 AM
NewR
Apr 9, 2003 09:19 PM
mityVR6
Mar 26, 2003 08:22 PM
RATEDR
Mar 1, 2002 10:37 AM
