Rear Brake Problem
I pulled off the rear wheels, removed the calipers, took old pads off, put new ones into place, and WTF now it doesen't go on the rotor. I then walked into the garage, grabed a "C" clamp in order to compress the "you know," only it would not compress. I removed the reservoir cap, and loosened the nipple behind the caliper(I slipped a hose with brake fluid over the nipple prior to loosening to prevent air from getting into the line)but it still will not compress. What am I doing wrong? Any help is much appriciated. Thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsi »</TD></TR><TR><TD CLASS="quote">Sounds like you have a seized caliper. Get a new one or a rebuilt one.</TD></TR></TABLE>
very likely ... if it is just hard to depress the piston because the C clamp won't fit on it right, try picking up a disc brake spreader from autozone or checker
were you having some kind of problem that made you want to change the pads in the first place?
very likely ... if it is just hard to depress the piston because the C clamp won't fit on it right, try picking up a disc brake spreader from autozone or checkerwere you having some kind of problem that made you want to change the pads in the first place?
no, I just bought the car, and wanted to change the brake pads. The rear passenger side brake however would squeel really bad for about the first 5 min of driving and then it would go away.....kinda weird. I will go pick up a spreader and see if that does the trick....thanx for all the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mattamotor »</TD></TR><TR><TD CLASS="quote">yes rear brakes twist in ,they do not push in.</TD></TR></TABLE>
Thank you.
Christ... why are people posting that you clamp them in. Wrong forum anyways, try tech.
Thank you.
EDWINV00SI
13
Mar 28, 2011 12:40 PM
wizzards581
Sep 6, 2003 12:15 PM
