Progressive Shift Light
I've seen them on indy and formula one cars.
The only aftermarket one available that i have found is made in Australia and is $171. It's made by Ecliptech and is called the Shift I.
http://www.ecliptech.com.au/
Does anyone know if there any other different ones?
I remember somebody posting about this before, but it's been awhile. Read through these, they should be helpful (although a little dated).
https://honda-tech.com/zerothread?id=613034
https://honda-tech.com/zerothread?id=721559
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley »</TD></TR><TR><TD CLASS="quote">Many of the current crop of sub-$1000 data acquisition units have them...
Yeah, probably the best answer.
otherwise, last time I was looking for one, Spa made one. You could look them up.
-Chris
-Chris
i still like the idea of a audible shift indicator better. it has a signal output you can use to connect to the dash lights or your own shift light too.
http://www.modifry.com/products/rlb/index.htm
http://www.modifry.com/products/rlb/rlb_demo.avi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Q - Can I use the Shift Beeper on other cars or will it only work on the S2000?
A - The standard Shift Beeper will work on any 4, 6, 8, or 10-cylinder engine that has a digital tachometer signal. Generally any car with electronic fuel injection and an ECM or ECU will provide a digital tach signal, so that covers a lot of cars. The Shift Beeper should NOT be used on older cars with distributor/points/coil type ignition systems, as it could damage the Shift Beeper module. </TD></TR></TABLE>
Modified by Tyson at 11:21 PM 7/5/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F »</TD></TR><TR><TD CLASS="quote">
-Chris</TD></TR></TABLE>
I had a SPA one in the H1 car last year....honestly I can say that I didn't really notice the pretty colors before the red showed up. Needless to say I took it out for a regular one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">i still like the idea of a audible shift indicator better.
Most if not all of the early Mazda rotary cars had those from the factory. The RX-2's was awful sounding. Really really awful...
soodominican
May 13, 2008 01:23 PM
