Offset Bushings?
Anyone know where I can get a set of Offset Bushings for an ITR? Fortunately I have a good friend that has offered to make a set for me, but I wouldn't want to put him through the trouble unless absolutely necessary...(thanks Jeff
Hey! I thought we couldn't use Delrin in the suspension components on this car. I thought it would bind. How much camber are you getting from the front now? I've already got -1.2 in the rear, but only -1.5 up front. I'd like to see -2 to -2.5. Stupid SCCA rules
I wish we could run that new Skunk kit up front, and the Mugen kit in the rear.
Warren
I wish we could run that new Skunk kit up front, and the Mugen kit in the rear.Warren
For IT rules, believe you can use any type of bushing material. Isn't Delrin the harder than poly...I thought it was, but I could be wrong?
I believe I have about the same as you do (-1.3ish in rear, and -1.5ish in front). Wish I could get about -3 degrees (and be legal)...that's all
Bushings are free in IT and Street Prepared (and in Honda Challenge
The delrin works fine. I have 2.3 negative left front and 2.2 negative right front. That seems to be about perfect for the Hoosiers. Temps look great across the face (except on concrete... the temps are just plain nuts and make no sense at all).
)The delrin works fine. I have 2.3 negative left front and 2.2 negative right front. That seems to be about perfect for the Hoosiers. Temps look great across the face (except on concrete... the temps are just plain nuts and make no sense at all).
I asked Colletti about using Delrin, and he said they tried it. They would bind and shear the bolts. Oops!
Then again, we're not running insano spring rates. Are you using Delrin for all the bushings, or just the inner upper control arms?
Warren
Warren
Wdpfreak145
Jan 19, 2015 05:52 PM
Ausmith
66
Jun 11, 2007 10:06 PM
