Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Need help for a rattle.
Old Dec 19, 2003 | 07:18 PM
CivicSiRacer's Avatar
Default Need help for a rattle.
I installed Ground Control coilovers with Koni shocks in January 2002. About middle of this year I started getting a rattle on the passenger's side rear. I thought it was my A'PEXi N1 exhaust hitting the gas tank and fixed that. But now I'm getting a rattle on the driver's side rear.
Any idea what it could be? I thought it could be the shocks/springs, but before I go dismantling it in the damn cold, I thought maybe you guys could come up with some ideas.
Thanks!
Mike
Old Dec 19, 2003 | 07:22 PM
JeffS's Avatar
Default Re: Need help for a rattle. (CivicSiRacer)
My first step would be the check the torque on the spring hat.
Old Dec 19, 2003 | 08:48 PM
MattG's Avatar
New User
My spring will occasionally rub the GC sleeve. All I do is jack the car up and spin the spring and make sure its lined up correctly. Generally this fixes all the noises. However, my comptech swaybar endlinks will rattle if I go over a "washboard" set of bumps.
Otherwise just make sure everything is tight. Also make sure your car is clean and the noise is not something rolling around.
Old Dec 20, 2003 | 11:08 AM
Todd Reid's Avatar
Default Re: Need help for a rattle. (MattG)
be sure to check the rear sway bar mounts; all of them. i have had the mounting hardware come loose/break before during the winter months...
if you have a spare and jack still in the car, be sure to make sure that they are secured. they can make a heck of a racket when loose....
the last thing to check might be the shocks; the shocks on my Cobra rattle/clunk like crazy when cold for the first 5 minutes or so; i think they are worn out and have leaked substantially.... when they warm up from friction, they seem to quiet down... Tokico Illuminas, btw.
good luck
Golddddddd
Suspension & Brakes
15
Nov 14, 2012 10:27 AM
zerovandez
Suspension & Brakes
Mar 23, 2009 02:57 PM
tvrsir
16
Jun 1, 2005 12:39 PM
deviant1
Apr 14, 2004 06:03 AM
