Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Looking for info....
Old Nov 15, 2002 | 03:44 PM
hondacivic4g's Avatar
Default Looking for info....
Did a search, trying to find out if any one has experience with Eibach Road race springs? http://eibach.com/index1.htm And if one knows the spring rates , or where I can find them?
This is for a 91 Hatch SI. Thanks-Jason
[Modified by hondacivic4g, 8:37 PM 11/15/2002]
[Modified by hondacivic4g, 8:39 PM 11/15/2002]
Old Nov 15, 2002 | 04:01 PM
jc836's Avatar
Default Re: Looking for info.... (hondacivic4g)
I will assume you are referring to the Eibach ERS series springs. If you are going to use them with sleeves-check with either Skunk or Ground Control. You can also do a search on the Eibach website.
If this is not what you had in mind you can also look at the Neuspeed springs and give APS a call (free) and talk to tech.
Old Nov 16, 2002 | 01:11 AM
Tyson's Avatar
Default Re: Looking for info.... (jc836)
no, he means the "road race" line of springs that are a step above the "sportlines" that are a step above the "pro kit" in stiffness and amount of drop. not the ERS used for adjustable spring kits.
and no, ive not had any experience or heard of any experience of em.
Old Nov 16, 2002 | 11:03 AM
Default Re: Looking for info.... (Tyson)
Tyson is correct!
FLATOUTRACING
16
Aug 12, 2005 07:09 AM
SD_EM1
Aug 13, 2003 11:40 AM
Flux
May 2, 2002 08:18 AM
HugoR
Mar 27, 2002 08:53 AM
