Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Link or advice for buttonwillow
Old May 29, 2007 | 12:51 PM
n-c's Avatar
n-c
Default Link or advice for buttonwillow
Heading to buttonwillow 6/9 - 6/10 for HPDE
It's been a really long time since I've run the track CCW and I don't ever recall running it with Star mazda.
Any of you HC guys have a link to video running that configuration?
Also any advice you can give on which turns are important would be great.
I have run CW but I know going backwards totally changes things. Just looking at the track map I'm guessing it's pretty much flat out thru esses and again flatout from Star to Magic Mtn. (or whatever they call it now) and again pretty much flat out around Riverside until you hit the Bus stop, Flat out exiting bus stop until the left turn where the elevation change and the corner worker are. I haven't a clue on the next 2 or buttonhook.
Any knowledge would be sweet.
Old May 29, 2007 | 01:23 PM
FlyZlow's Avatar
Default Re: Link or advice for buttonwillow (n-c)
Check out edomoto.com. Edik puts his HC videos up on that site and he's always quick at BW. I believe he has both CW and CCW videos on there.
Old May 29, 2007 | 01:49 PM
Crazydave's Avatar
Default Re: Link or advice for buttonwillow (FlyZlow)
I had a hard time braking, turning, and shifting at the same time on cotton corners. (i don't think I will do that again) YMMV
I think I ran out of talent and ended up pointed south looking at the corner worker as he flew a yellow flag. (I've been off track on this turn several times)
Look forward to seeing you there. (look for the black EG with bad paint job)
Modified by Crazydave at 3:03 PM 5/29/2007
Modified by Crazydave at 4:31 PM 5/29/2007
Old May 29, 2007 | 03:02 PM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n-c &raquo;</TD></TR><TR><TD CLASS="quote">Also any advice you can give on which turns are important would be great....
I have run CW but I know going backwards totally changes things. Just looking at the track map I'm guessing it's pretty much flat out thru esses and again flatout from Star to Magic Mtn. (or whatever they call it now) and again pretty much flat out around Riverside until you hit the Bus stop, Flat out exiting bus stop until the left turn where the elevation change and the corner worker are. I haven't a clue on the next 2 or buttonhook.</TD></TR></TABLE>
Sounds like you've got a pretty good handle on it. I am hardly the BW guru, but I can tell you that the last turn before leading onto the front straight (Sunrise) is the widow-maker going CCW. It's very easy to over cook that turn. Then once you get out of shape, the instinct is to try and save it. That puts most guys (including some real rock-stars) right into the wall.
The fastest turns are always the most important. And those leading into the fastest parts of the track (the straights). The ones where I lose the most time at BW are always Sunrise and Sunset, at either end of the front straight.
Old May 29, 2007 | 03:20 PM
Crazydave's Avatar
Default Re: Link or advice for buttonwillow (thawley)
what turn would this be at BW?
just messing with you big-guy...
Old May 29, 2007 | 03:50 PM
WWDTrackRacer's Avatar
New User
http://www.coastaldriving.org/...w.pdf
These are PDFs with driving line info. Been around for years so might be a tad out of date.
Modified by WWDTrackRacer at 8:29 PM 5/29/2007
Old May 29, 2007 | 03:59 PM
thawley's Avatar
Default Re: Link or advice for buttonwillow (Crazydave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">what turn would this be at BW?
just messing with you big-guy... </TD></TR></TABLE>
NO SOUP FOR YOU
Old May 30, 2007 | 11:41 AM
RED_90TEG's Avatar
From: where i stunt SAND CANYON in Southern California
http://WWW.EDOMOTO.COM
Old May 30, 2007 | 12:27 PM
Crazydave's Avatar
Default Re: (RED_90TEG)
here is config 1 CCW:
http://edomoto.com/racing/videos/wchcJune1006.wmv
Old May 30, 2007 | 12:53 PM
prkiller's Avatar
Default Re: (Crazydave)
Being as it looks like you have a hard to drive CRX and not the wimpy integra, you might want to check out this video too!
http://youtube.com/results?sea...earch
Lots of vids there. Some of Button!
Old May 30, 2007 | 01:06 PM
EdoMoto's Avatar
Default Re: (prkiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prkiller &raquo;</TD></TR><TR><TD CLASS="quote">Being as it looks like you have a hard to drive CRX and not the wimpy integra, you might want to check out this video too!
Yes watch how the Wimpy Integra whoops the CRX's *** as it was sitting still. CRX
Edo
Old May 30, 2007 | 01:13 PM
gsr20det's Avatar
CRX's aren't hard to drive, they're just hard to drive faster than Integras. That being said, if anyone knows how to drive a CRX faster than an Integra at Buttonwillow, it's Jeremy. He's one of the fastest out there that I know of. He's blindingly fast, nearly just a blur. You'll miss him if you blink. He's so fast, that on a 6 megapixel camera, he barely takes up 2 pixles! It looks like a smudge on the lens.
You'd have to be some kind of superstar or legendary road racer to beat Jeremy at Buttonwillow
Tom #57 WCHC H4
Founder of the IBJC
Old May 30, 2007 | 01:15 PM
prkiller's Avatar
Default Re: (EdoMoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdoMoto &raquo;</TD></TR><TR><TD CLASS="quote">
Edo</TD></TR></TABLE>
Oops, I forgot to put the in there!
Oh well....
Old May 30, 2007 | 01:16 PM
prkiller's Avatar
Default Re: (gsr20det)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr20det &raquo;</TD></TR><TR><TD CLASS="quote">CRX's aren't hard to drive, they're just hard to drive faster than Integras. That being said, if anyone knows how to drive a CRX faster than an Integra at Buttonwillow, it's Jeremy. He's one of the fastest out there that I know of. He's blindingly fast, nearly just a blur. You'll miss him if you blink. He's so fast, that on a 6 megapixel camera, he barely takes up 2 pixles! It looks like a smudge on the lens.
Tom #57 WCHC H4
Founder of the IBJC </TD></TR></TABLE>
HAHA!!!
Wonder if anyone will figure out the IBJC!
Old May 30, 2007 | 01:24 PM
JuanTushag's Avatar
wow its getting thick around here,
I think you may have your hands full at Buttonwillow, that is unless of course we see your new driver alter-ego come out DARTH GASSEOUS
Old May 30, 2007 | 01:29 PM
EdoMoto's Avatar
Default Re: (JuanTushag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JuanTushag &raquo;</TD></TR><TR><TD CLASS="quote">wow its getting thick around here,
Look who found his way to the internet. Welcome Juan Dushbag
Edo
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prkiller &raquo;</TD></TR><TR><TD CLASS="quote">Wonder if anyone will figure out the IBJC! </TD></TR></TABLE>
I Borrow Jeremy's Corset?
Old May 30, 2007 | 01:31 PM
gsr20det's Avatar
The members of the IBJC already know who they are for they have nearly drown in the river of tears whilst hearing the cries of defeat and song of injustice
For those not certain of their membership status in the IBJC, please contact our membership officer, Edo via PM.
Tom #57 WCHC H4
Founder of the IBJC
Old May 30, 2007 | 01:33 PM
Chris F's Avatar
Default Re: (thawley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thawley &raquo;</TD></TR><TR><TD CLASS="quote">
I Borrow Jeremy's Corset?</TD></TR></TABLE>
Thaaaaanks John.... :vomit:
Old May 30, 2007 | 01:34 PM
gsr20det's Avatar
Nice Moobs Thawley! Is that a Johnny Mac bikini wax ya got goin' on there?
EdoMoto's Avatar
So Im the president of IBJC nice how much do i get paid.
Edo
Old May 30, 2007 | 01:35 PM
thawley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EdoMoto &raquo;</TD></TR><TR><TD CLASS="quote">So Im the president of IBJC nice how much do i get paid.
See photo above, big guy.
Old May 30, 2007 | 01:38 PM
EdoMoto's Avatar
THAWLEY is my First member welcome. Put that Corset on Thawley . And Come on in.
HEHEHEHHEHEH
Edo
Old May 30, 2007 | 01:41 PM
thawley's Avatar
I don't want to belong to any club that would have me interact with other members.
Old May 30, 2007 | 01:43 PM
gsr20det's Avatar
Mr (President) Edo, with all due respect please keep what you do with Thawely's member between you and him. However, it looks like Thawley just opted out of the Friday Night Sword Fight you had planned....
