Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
How to shift without clutch???
Old Mar 28, 2003 | 10:49 AM
blackhatch13's Avatar
Default How to shift without clutch???
What is the trick behind shifting without the clutch? has anyone done that b4? I have seen it and dunno how to do it.....
I would like to learn this technique if anyone is willing to share the info...
And what is the whole truth behind double clutching.....what is it n e ways......is it rpm matching??
Old Mar 28, 2003 | 10:51 AM
BryanSprinkel's Avatar
Default Re: How to shift without clutch??? (blackhatch13)
REV to 8-9k RPM's and yank the shifter back to second, yep that's about it.
Old Mar 28, 2003 | 10:57 AM
phat-S's Avatar
Wow, you are getting a lot of love quickly.
When you are going along (slowly) on a road, try moving the shifter out of gear w/out the clutch (and go ahead and get off the throttle too). With the gear selector in neutral, place a teeny-tiny amount of pressure on the shifter to the next gear up (or down) and blip the throttle. As the revs fall, you'll notice the gear shifter go into the gear (when the revs match). At least that's how I learned to do it some 16 years ago.
Old Mar 28, 2003 | 11:01 AM
Geezer's Avatar
Not much point to shifting without the clutch, unless you have a racing tranny with dog gears. Not much point to double clutching either, if your gearbox works OK. Look here http://www.turnfast.com/tech_driving..._heeltoe.lasso for good info on heel & toe and rev matching.
What type of organized competition were you going to use this in, anyway?
Old Mar 28, 2003 | 11:03 AM
joeseph's Avatar
Default Re: How to shift without clutch??? (phat-S)
I used this method when I was first learning to drive (a Land rover with a messed up clutch)
I don't know why you would want to use i if you didn't have to though.
[Modified by joeseph, 2:07 PM 3/28/2003]
Old Mar 28, 2003 | 11:05 AM
phat-S's Avatar
Default Re: How to shift without clutch??? (joeseph)
I found it rather helpful knowledge when I snapped a clutch cable in the middle of a practice session 8 turns from pit lane.
... and I like practicing LFB while downshifting too
Old Mar 28, 2003 | 11:52 AM
urbanlegend21's Avatar
New User
that's because you are a WILD & CRAZY GUY!
Old Mar 28, 2003 | 02:37 PM
sackdz's Avatar
Then don't be cheap and get a pnumatically controlled sequential gearbox like everybody else!!
Old Mar 28, 2003 | 03:19 PM
phat-S's Avatar
Default Re: How to shift without clutch??? (sackdz)
pneumonia squishy whatever isn't legal in IT.
Old Mar 28, 2003 | 03:20 PM
.RJ's Avatar
.RJ
I'm gonna start docking points for all you n00b users who cant manage to post a competition related topic.
Spinks
Honda Civic (2006 - 2015)
Nov 23, 2010 06:01 PM
konvikt
Jan 20, 2007 08:01 PM
iixerOii
May 17, 2005 11:45 AM
ronman92
Apr 17, 2003 08:26 PM
