Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Got LSD?
Old Aug 3, 2009 | 06:18 AM
Natural Aspirations's Avatar
Default Got LSD?
Currently running a stock OEM ITR LSD, wondering if there is a decent advantage or disadvantage to changing to a clutch type LSD or a preloaded heli style lsd.
Car is mainly used for auto-cross and would like to eventually make it to some road course events when I get a little more experience.
Old Aug 3, 2009 | 07:19 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
Default Re: Got LSD?
Not sure about autocross but for road courses, you have a lot more chances of hopping the curb and caused the inside front tire to catch air. When that happens, the ITR LSD (helical) would become ineffective.
Old Aug 3, 2009 | 08:14 AM
MBellRacing's Avatar
What Wai said for sure... I tracked a couple peoples' Minis and they have a helical LSD. Good because they require little service, but a pain in the *** if you ever pick up the front. Being an AutoXer, you're probably doubting every getting the front in the air, but I assure you that it will be on a road course.
Old Aug 3, 2009 | 08:25 AM
slofu's Avatar
The OEM ITR LSD is good, but not nearly as "active/aggressive" as is a clutch-type LSD. You'll most certainly benefit from the switch, provided you maintain it properly.
Old Aug 3, 2009 | 04:47 PM
Aquafina's Avatar
What ^ they all said. I lifted the front left quite a few times at Autobahn earlier this summer and its not very fun when the helical LSD becomes an open diff.
Though if you aren't trying to push it and don't mind getting a little off line, that is a cheap fix (sometimes) until you feel like spending the money on a clutch type LSD.
Old Aug 3, 2009 | 08:03 PM
Stinkycheezmonky's Avatar
Suspetise...
You'd lift the front less if you drove on the curbs less
Old Aug 3, 2009 | 08:18 PM
wenlyone's Avatar
so when one side lifts up, the other side won't put down power?
I have the quaife lsd, it is the same as itr one right? its no good?
Old Aug 3, 2009 | 09:18 PM
RagingAngel's Avatar
The quaife and ITR unit is similar in design where if one wheel is unloaded (in the air) it will not be able to function properly.
Quaife unit is better in the sense that it can handle more power and has a great warranty and in my limited experience I feel performance wise, it is also slightly better as it appears to have a higher preload which enables it to react faster than the ITR LSD.
For a weekend toy or racecar only whether it be autoX or track - a clutch pack LSD is ideal IMO - for drag, a helical is fine.
Old Aug 3, 2009 | 09:25 PM
wenlyone's Avatar
I wish someone started this thread 2 years ago. But since I never hopped the front, I never experienced this issue.
How does helical work? I thought lsd just locks allow the wheel that isn't slipping to still get power.
Old Aug 3, 2009 | 09:27 PM
wenlyone's Avatar
I read this when I bought the quaife, I thought it is ok to have one wheel with 0 grip.
http://auto.howstuffworks.com/differential6.htm
Old Aug 3, 2009 | 09:28 PM
wenlyone's Avatar
oh damn. I read the wrong page. 0__o
great, what a waste of money.
Old Aug 3, 2009 | 09:55 PM
Don't feel too bad about the choice you made - the Quaife is still an excellent unit and it doesn't require rebuilds unless you somehow blow it up...
you also mention you've never jumped/hopped curbs anyway - so really, it's a non-issue in your specific situation.
Old Aug 3, 2009 | 09:58 PM
wenlyone's Avatar
under what condition will you lift your front wheel? I am still learning in the advance hpde. I guess I am not driving fast enough to lift front wheel up right?
Old Aug 3, 2009 | 11:15 PM
"lifting" can occur when you're bouncing off the gators/curbs or when you're going fast enough to launch the car over a crest - but this may not even be possible depending on the tracks you attend...
Old Aug 4, 2009 | 05:20 AM
Lo-Buck EF's Avatar
Has anyone tried the wavetrack? Its supposed to be better than the quaife when wheels are off the ground.
Old Aug 4, 2009 | 05:26 AM
wenlyone's Avatar
Since I never picked up a wheel, I can only imagine.
But wouldn't it be bad to have power to the wheel on the ground? Since when the other one lands, it will catch, wouldn't that give the car a suddent yank to one side?
Old Aug 4, 2009 | 05:34 AM
Lo-Buck EF's Avatar
Not if the wheel in the air is at the same speed. Another issue is when the airborne wheel comes down with power on, the axle takes a beeting.
Old Aug 4, 2009 | 05:35 AM
wenlyone's Avatar
so is it better to be netrual when one wheel is up? can you feel it when one wheel is up?
Old Aug 4, 2009 | 06:00 AM
Suspetise...
Really, you shouldn't be lifting a front wheel in a FWD car. Short of really nailing a gator hard I don't ever do it, and even then would consider it a "mistake" (not the fast way around that corner).
Old Aug 4, 2009 | 06:46 AM
wenlyone's Avatar
so does that mean I didn't wast my money? ^__^
Old Aug 4, 2009 | 07:07 AM
Lo-Buck EF's Avatar
No you didn't.
To clarify-any front wheel-in-the-air I'm talking about is a result of curb banging. In a turn like that kink at CMP, bangin the gator is the hot way.
Old Aug 4, 2009 | 07:18 AM
Dogginator's Avatar
Daisy... Daisy...
Light left foot braking to apply torque to the lifted wheel?
Old Aug 4, 2009 | 07:50 AM
Suspetise...
I think the amount you'd slow down would not outweigh whatever benefit of loading the lifted wheel.
And Spence, two wheels up through the Kink? I haven't driven there, but also hadn't heard that.
Old Aug 4, 2009 | 07:53 AM
wenlyone's Avatar
isn't 2 wheel up dangerous?
Old Aug 4, 2009 | 08:39 AM
Suspetise...
Eh, not too big of a deal. I mean, it's kind of relative. If you're talking about this:
then yeah, that could be dangerous Most of the time it's just a couple inches though, and for a very brief period of time.
