Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
fsp
Old Jun 25, 2012 | 09:24 PM
sanantonlude's Avatar
Default fsp
I could not find the limitations on fsp. so....
What are the limitations on fsp, i run my ek, with a y7.
as of now i have full exhaust, intake, sturt bars, si rear sway bar, ebay springs, with a 250 rate. for tires i am using dirrezza dr101, 195/50
I only have about 8 autox events done.
What would be some other good add ons to help me out, without jumping out of my class. Theres a scion tc with lsd, in my class, and hes been doing good.
Old Jun 25, 2012 | 10:31 PM
tronic's Avatar
Default Re: fsp
from
http://www.scca.com/assets/2012_Solo...ry_reduced.pdf
pg 193
FSP car classification:
Civic (non-Si) (1996-2000)
So you can put any engine and/or transmission into any chassis on that line.
The most cost effective order of things to do, IMO:
tires: 225/45-15 Hankook RS3 if you need to run street tires. There are many decent 205/50-15 choices, too. Hoosier A6's, as big as you care to cut your fenders for, if you run R-comps.
rear sway bar: go CTR instead of Si
shocks: adjustable and able to handle the spring rate
wheels: light and wide
more spring : 400-500lb for streetable
LSD: it makes driving FWD more fun
Old Jun 26, 2012 | 04:01 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: fsp
^^All correct
I run FSP
I have all that minus the A6's
Old Jun 26, 2012 | 09:16 AM
Default Re: fsp
If I sway the single to a dual cam, won't that put me in smf?
Lsd in a single cam tranny?
Old Jun 26, 2012 | 09:26 AM
ReDemoN's Avatar
Default Re: fsp
A motor swap would put you into SMF
A lsd in the sohc u can stay in FSP
Old Jun 28, 2012 | 09:15 AM
Default Re: fsp
I found a lsd for 300 on eBay, is that a good price, I haven't heard to much on lsd's for a sohc
Old Jun 28, 2012 | 10:22 AM
tronic's Avatar
Default Re: fsp
If it's a quality LSD like a Quaife, Kaaz, or Mfactory, yes $300 is cheap. Install may be expensive if you can't do it yourself, though.
I wouldn't bother with an LSD until your grip is improved (suspension, wheels, tires).
Old Jun 28, 2012 | 02:34 PM
Default Re: fsp
ah... I see
Well I'm going to try and find me a y8 inatke manifold first
Followed by some extra rims, and I think I'm going to try the Dunlop star specs.
I had done a mini me swap, but the head that was sold to me had bent valves, I didn't want to mess with it n gave it away.
I might get my y8 tranny fixed as well, I think it might be better than my y7
Old Aug 5, 2012 | 02:05 PM
Default Re: fsp
I'm debating on getting a h brace.
N e one have any comments on the h brace, don't know n e one that has had one,
And im waiting on my thermal wrap to come in, let c how much I can cover up with 2inchx50 feet of wrap
Old Aug 5, 2012 | 06:13 PM
civexspeedy's Avatar
Default Re: fsp
Why run FSP when you can run STC? Technically costs less to build. Either way that chassis isn't the best for either class..
Ditch the H-Brace, dead weight.
Old Aug 5, 2012 | 07:39 PM
Default Re: fsp
Still learning, n haven't got my extra set of rims to run better tires
Old Aug 5, 2012 | 08:50 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: fsp
Then stick to what you have now and continue learning.
Chances are you are leaving time on the track still.
Invest in some coaching.
Old Sep 27, 2012 | 10:23 AM
Default Re: fsp
Here's a video of the civic
I wrap the header, got a y8 manifold but havent installed it yet,
Was wondering what kind of tranny fluid should I run on this d16, it's auto x n dd,
Was think of staying with Honda but what weight too?
Thanks hope the vid works
Old Oct 22, 2012 | 07:33 PM
Default Re: fsp
Ok so I'm building a lsv and I'm going to buy a shell to drop it in...
It's giving to be just a track, autox, car
I really want to drop it in a eg
But there's a del sol shell for a good price here in town... my question is
Is the del sol a good car to auto x, track in. Haven't seen many del sols for track use
TOO MUCH TORQUE
Suspension & Brakes
12
Apr 23, 2009 04:01 PM
coot_er
13
Jul 17, 2007 06:22 AM
Sarge! Carry On!
Honda Civic (2006 - 2015)
Jun 14, 2007 05:06 PM
EK4civichatch
13
Apr 21, 2004 06:16 AM
Hracer
19
Oct 23, 2002 01:10 PM
