Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
EF harness mounting
Old Jun 13, 2003 | 05:45 AM
Audipwr1's Avatar
Default EF harness mounting
guys with efs, where do you attach the left and right belts to on your cars?
I see a place for the belt mount on the left side but its a bit far back and would mess up the geometry.
Some pics of the pieces you made or bought, and suggestions would be great
its a 5 point harness, 2 up to the cage, the submarine belt, then the two sides
Old Jun 13, 2003 | 06:12 AM
.RJ's Avatar
.RJ
Default Re: EF harness mounting (Audipwr1)
i'd mount them on the floor w/ reinforcement plates, no matter what type of car it is.
Old Jun 13, 2003 | 06:18 AM
Audipwr1's Avatar
Default Re: EF harness mounting (.RJ)
its a real narrow area between the seat and the side of the car, so i am worried that may not work. There would have to be a piece attached to the floor that went directly up and the harness would have to mount to that I would think.
Old Jun 13, 2003 | 06:21 AM
.RJ's Avatar
.RJ
Mount it just behind the seat on hte floor. Or mount it under the seat on the floor.
Old Jun 13, 2003 | 06:39 AM
Audipwr1's Avatar
RJ I need some pics damnit!
Old Jun 13, 2003 | 10:56 AM
EF_LSVtec's Avatar
Anything wrong in using the stock seatbelt mounting points for the lap belts?
Old Jun 13, 2003 | 11:10 AM
.RJ's Avatar
.RJ
Default Re: EF harness mounting (EF_LSVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">Anything wrong in using the stock seatbelt mounting points for the lap belts?</TD></TR></TABLE>
yes. you cant have a 5 point harness function as intended using mounts for a 3-point belt that uses an entirely different mechanism as well as restraint.
Old Jun 13, 2003 | 11:28 AM
EF_LSVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
yes. you cant have a 5 point harness function as intended using mounts for a 3-point belt that uses an entirely different mechanism as well as restraint.</TD></TR></TABLE>
obviously...I have a 4 pt harness...used stock seatbelt pts for left and right side lap belts and rear seat stock mounting pts for shoulder belts...for 5 pts the remaining middle belt is usually mounted on the floor paired with a heavy duty plate (like one suggestion on this thread). All he asked is where to put the left and right side lap belt...
Old Jun 13, 2003 | 11:29 AM
.RJ's Avatar
.RJ
obviously...I have a 4 pt harness...used stock seatbelt pts for left and right side lap belts and rear seat stock mounting pts for shoulder belts...for 5 pts the remaining middle belt is usually mounted on the floor paired with a heavy duty plate (like one suggestion on this thread). All he asked is where to put the left and right side lap belt...</TD></TR></TABLE>
This mounting is wrong... wrong... wrong.... i suggest you change it.
You never mount to the rear stock seat belt mounting points, even if you are using a rollbar.
Old Jun 13, 2003 | 11:34 AM
EF_LSVtec's Avatar
You never mount to the rear stock seat belt mounting points, even if you are using a rollbar. </TD></TR></TABLE> Where do you suggest I mount my shoulder harness? BTW, i dont have a roll bar/cage...
Audipwr1's Avatar
yeah man you got to make plates and hold it down correctly, I need some pictures of it done correctly
Old Jun 13, 2003 | 11:39 AM
.RJ's Avatar
.RJ
search this forum, including archived topics
Old Jun 13, 2003 | 01:06 PM
the DR.'s Avatar
I have some pics but WTDR is down at the moment, and as to using stock locations - 90/91 have door mount seatbelts so thats not possible (i also have a 91) I basically copied some of the other H4 cars out here in the WCHC, IM me and I can email you the pics if you'd like.
Old Jun 13, 2003 | 01:20 PM
Audipwr1's Avatar
Default Re: EF harness mounting (SlicedBread)
im'ed ya
thanks
Old Jun 24, 2003 | 06:37 AM
keithv's Avatar
anyone have pics of how they mounted the submarine harness?
Old Jun 24, 2003 | 08:50 AM
Lo-Buck EF's Avatar
Default Re: EF harness mounting (keithv)
for the sub belt, i drilled through the floor and mounted an eye hook/snap ring set-up. for my laps (i have '91 too) i mounted the laps to the seat attachment points. aka, inbetween the seat and the floor. i am aware that my lap set-up is incorrect tho. so ill be picking up more eyehooks, snap rings and backing plates....
-spenc
Old Jun 24, 2003 | 09:05 AM
stevel's Avatar
When I was at the Speed WC race at Limerock even though there was a fully SCCA Pro spec cage installed (obviously) one of the nicest bmw's there had the shoulder harness attached to the rear seatbelt mounting points. Just thought I'd share.
How come it's wrong?
s
Old Jun 24, 2003 | 09:37 AM
Crack Monkey's Avatar
Default Re: EF harness mounting (stevel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevel &raquo;</TD></TR><TR><TD CLASS="quote">How come it's wrong?</TD></TR></TABLE>
1. Belt is too long. Short is better. The weave stretches more than you can imagine in an accident so keep them short. Rally cars seem to be an exception, but I have yet to figure out why (maybe they want the stretch for the occassional plunge off a cliff?).
2. Geometry is very often wrong - what are the chances the rear belt mount is straight back along the centerline of the seat and at the correct angle vertically (ie does not attach too low).
Why do you have a harness and no rollover protection?
Old Jun 24, 2003 | 09:44 AM
.RJ's Avatar
.RJ
Default Re: EF harness mounting (Crack Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">2. Geometry is very often wrong - what are the chances the rear belt mount is straight back along the centerline of the seat and at the correct angle vertically (ie does not attach too low).</TD></TR></TABLE>
You dont want the belt attached very low behind the seat, could cause spinal compression in an impact.
Old Jun 24, 2003 | 11:26 AM
Lo-Buck EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">Why do you have a harness and no rollover protection?</TD></TR></TABLE>
i have roll protection. and although its not the safest way to go about it, some clubs will let u run with a harness w/o roll protection.
iLLA
12
Jan 12, 2006 10:43 AM
Race Egr
Sep 23, 2005 08:34 AM
Kilburn
Apr 17, 2005 05:09 PM
Stinkycheezmonky
36
Oct 30, 2003 08:13 AM
6ghatch
Jan 26, 2003 11:29 AM
