Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
A cheap tire to learn on
Old Feb 17, 2004 | 09:30 PM
LX4CYL's Avatar
Default A cheap tire to learn on
I've decided that I should definitely hold off on buying a set of wheels+tires for autocross until I've truely figured out how to drive my soon-to-be H-Stock Honda Accord.
That being said, I'm going to go ahead and purchase something cheap+decent to mount on my stock 15x6" steel wheels. I'm looking for a 205/60-15 set of tires, and I was wondering which would be better for me:
Sumitomo HTR-200 (High Performance Summer)
Falken ZE-512 ZIEX (High Performance All season)
Both are practically the same price for me (around $41+), so I guess I have a choice
Old Feb 18, 2004 | 01:11 AM
ion_four's Avatar
Default Re: A cheap tire to learn on (LX4CYL)
On my VERY limited (student) budget, I am going to use a 195/60/14 Falken Azenis Sport. You can also find 205/50/15 Azenis Sport for about $55 a piece and I would wager they are MUCH better than the 512s, in the dry. Not quite as good in the wet, however.
Old Feb 18, 2004 | 03:02 AM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LX4CYL &raquo;</TD></TR><TR><TD CLASS="quote">
hmmm, that is kindof a tough choice,
I think they are pretty similar tires.
I might lean toward the falken.. if for nothing more than just the trustworthy brand name
Old Feb 18, 2004 | 03:19 AM
.RJ's Avatar
.RJ
Default Re: A cheap tire to learn on (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">I might lean toward the falken.. if for nothing more than just the trustworthy brand name </TD></TR></TABLE>
Those Ziex tires suck.... at least in dry grip.
Old Feb 18, 2004 | 03:56 AM
PseudoRealityX's Avatar
the Kumho 711 is a good, predictable, cheap, fairly long lasting street tire.
I've autocrossed on these a number of times when it was too wet, or I was too lazy to switch to my R comps. I think you can learn faster on street tires anyway, especially with smoothness of pedal and steering inputs.
my vote would be for them. They come in a lot of different sizes too. so you might be able to work with a 225 upfront and 205 in the rear.
Old Feb 18, 2004 | 04:09 AM
LX4CYL's Avatar
Default Re: (PseudoRealityX)
keep in mind that I'll probably be using on the street for a while so I'll be limited to 205/60-15 on my stock 15x6" wheel.
Old Feb 18, 2004 | 04:21 AM
.RJ's Avatar
.RJ
Default Re: (LX4CYL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LX4CYL &raquo;</TD></TR><TR><TD CLASS="quote">I'll be limited to 205/60-15 on my stock 15x6" wheel.</TD></TR></TABLE>
Why? A 205/50 will work fine, and there are plenty of good choices in that size.
Old Feb 18, 2004 | 04:38 AM
LX4CYL's Avatar
Default Re: (.RJ)
these are going to be used on the street for the next few months too...
Old Feb 18, 2004 | 04:40 AM
.RJ's Avatar
.RJ
So?
205/50/15 work fine on the street too.
Old Feb 18, 2004 | 04:49 AM
LX4CYL's Avatar
Default Re: (.RJ)
eh, my stock tire size is 195/65-15. You sure I won't kill my gas mileage or anything by changing to a 1" smaller diameter?
Old Feb 18, 2004 | 04:55 AM
emwavey's Avatar
Cheap tire? Go to a junk yard or tire shop and ask if you can have four "spent" tires. This is by far the cheapest way to go and will give you a lower traction threshold. Why would you want to do this? If you're talking about "learning" and not competing, this will allow you to feel what it's like to loose traction at a lower speed. Plus if you flat spot them, what have you lost? Virtually nothing. Once you learn the basics, then you can step up.
Have I done this? No, but it sounded like good advice to me when I heard it.
Remember the most important thing is to have fun and learn in the process.
anti-ing up my 2 cents.
Old Feb 18, 2004 | 05:01 AM
JeffS's Avatar
Is price a big factor? The Yoko ES100 is available in 205/60, 205/55, 205/50. It would be a better performing tire than these other two.
There are plenty of choices in 205/55
Between these two, I don't think it matters which you choose.
Old Feb 18, 2004 | 06:34 AM
LX4CYL's Avatar
Default Re: A cheap tire to learn on (JeffS)
I agree about the used tire deal, but I at least something semi-safe for the street, since my stock wheels are the only wheels I have for now.
The ES100s do come in 205/60-15, but I think I want to give the HTR200s a shot since it will be a good compromise between a cheap used tire, and a really nice tire like the ES100.
The HTR-200s are the best rated High Performance Summer tire at Tirerack, and for $41/tire you really can't beat it.
I've done my past 6 autocrosses on a nice set of 225/40-18 ES100s, shich I hoped to replace this summer, but I destroyed 2 of them on the street in an "accident."
I've realized that in the past 6 autocrosses, I haven't learned how to properly drive the car because it had a bit too much grip for a novice like me, so that's why I want to go with a semi-cheap tire on stock steel wheels
Old Feb 18, 2004 | 06:47 AM
Vracer111's Avatar
Hey, if you really want to learn car control try some Goodyear Allseason Touring Eagles whatevers...those tires are absolute crap! I Ga-rUN-tee' you'll learn car control better than I did on those tires. Absolutely horrible in the wet and search for traction in the dry (with an automatic Integra taking off 'gently'. ) They will even hydroplane on dry pavement if you say the magic word! So you won't even need to have a wet skidpad to learn car control with limited traction...
Vracer111, who actually strongly advises against getting the Goodyear Allseason Touring Eagle whatevers for daily driving. Might be a fine tire to learn about traction management in a controlled environment though.
P.S. - I plan on doing the Evolution school (still tentative if it will happen) on my stock wheels with the new BFG T/A 'everyday tires' I had put one. Stepping way down in traction from Azenis hopfully will be a good thing... Do you think you might want to go to the *potential* Evolution school (Thursday April 1st, no this not a joke either... ). Let James Rogerson know via e-mail if you are interested, I think we need at least 10 participents to make it happen.
Modified by Vracer111 at 9:59 AM 2/18/2004
Old Feb 18, 2004 | 08:32 AM
Civic242's Avatar
Lest we forget the Kumho 712 Supra. A very well manored tire that holds very well in the dry and wet and has a tell tale break away signal. Cheap and available every where in the 205/50-15 V or W tire size.
Old Feb 18, 2004 | 10:47 AM
LX4CYL's Avatar
lol, I'm fully aware of the other well known tires avaiable in 205/50-15, but I think I'm going to want to keep the stock diameter since I'll be using these on the street for a while. I really don't want to make the car look like a rollerskate or rev higher to get from point A to B, so the Sumitomo HTR-200s in 205/60-15 will have to do unless someone knows of something better in that size besides the ES100s that cost twice as much...
Old Feb 18, 2004 | 01:10 PM
Steppin Razor's Avatar
New User
Actually, Sumitomo owns Falken, so either way you're getting the same quality tire.
I'm guessing these would be daily drivers...do you need all seasons?
Old Feb 18, 2004 | 01:14 PM
LX4CYL's Avatar
Default Re: A cheap tire to learn on (Steppin Razor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steppin Razor &raquo;</TD></TR><TR><TD CLASS="quote">
I'm guessing these would be daily drivers...do you need all seasons?</TD></TR></TABLE>
nope no ice here. Did just fine with es100s in the winter
r2x's Avatar
r2x
Sounds like you've made your decision and are just looking for someone to agree?
Yes, get the most POS street tires you can find and learn on them. It'll make you a much better driver. Uniroyal Tiger Paws or something. Then, since they never wear down, when you finally do get a better auto-x tire, you'll still have good street tires for years to come.
Old Feb 18, 2004 | 01:40 PM
p0pe's Avatar
Go with the azenis in 205/50/15. The accord needs all the gearing help it can get.
Old Feb 18, 2004 | 03:39 PM
The HTR200s cannot even come close to the performance that the Kumho 711s will give you. And check the prices, you'll be amazed. The HTR200's sidewall is crap. It's way way too soft.
FWIW, I've had both of these tires. I've autocrossed on both too.
Old Feb 18, 2004 | 03:44 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LX4CYL &raquo;</TD></TR><TR><TD CLASS="quote">eh, my stock tire size is 195/65-15. You sure I won't kill my gas mileage or anything by changing to a 1" smaller diameter?</TD></TR></TABLE>
isn't that nearly 2" smaller?
195/65-15 = 24.98"
205/50-15 = 23.07"
who needs MPG?
Old Feb 18, 2004 | 04:20 PM
Solracer's Avatar
I am running on Sumitomo HTR200 right now and I like them. They have performed well on track and at autox's.
Old Feb 18, 2004 | 04:23 PM
Evan55's Avatar
Sumitomo HTRZ-II worked well for me.
Better grip than the Kuhmo 712 and slightly cheaper.
Dann6968
Jul 7, 2007 02:06 AM
bosco500
Jan 29, 2005 10:46 AM
JeremyL
22
Aug 19, 2004 08:36 AM
azian21485
Feb 12, 2004 01:55 PM
[Caster]
12
Jul 16, 2003 09:47 PM
