Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
adjustable way bars??
Old Oct 22, 2007 | 10:05 PM
miller's Avatar
Default adjustable way bars??
does anyone sell a front and rear adjustable sway bar for a 92-95 civic chassis?
Old Oct 23, 2007 | 05:50 AM
thawley's Avatar
Default Re: adjustable way bars?? (miller)
I doubt anyone makes a front bar that's adjustable, besides the tubular ones that reqire custom fabrication.
Both Progress and ASR make one for the rear I believe...
Old Oct 23, 2007 | 12:34 PM
turboteener's Avatar
Banned
I can build you a cockpit adjustable bar. You really only need a rear if it is for a Front driver, but I can do both. They aren't cheap.
Old Oct 23, 2007 | 02:21 PM
6spdKEG's Avatar
Default Re: (turboteener)
I once made some 91-95 MR2 turbo TRD hollow sway bars adjustable by flattening tube and drilling more holes in it. It worked nicely! There was room to make a hole closer to the end to make the bar softer and room to make one hole closer to the BEND to make it more stiff.
I used a 20ton hyd. jack press at work.
Heated the bar up red hot.
Pressed on each side
straighted
drilled holes
repainted
You could feel the difference.
I ended up liking the feel of the original holes though
Old Oct 23, 2007 | 02:33 PM
Banned
Old Oct 23, 2007 | 03:14 PM
Lo-Buck EF's Avatar
miller-are you guys building a road race car over there???
-spenc
Old Oct 23, 2007 | 04:47 PM
Banned
Hope they put the main hoop braces to the strut tower instead of the cross bar. JK.
Old Oct 23, 2007 | 06:15 PM
slammed_93_hatch's Avatar
good luck putting a speedway eng type bar on the front of any 88-01 honda/acura.
There just isn't much room with the double wishbone up front.
Old Oct 23, 2007 | 06:50 PM
Lo-Buck EF's Avatar
Default Re: (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">good luck putting a speedway eng type bar on the front of any 88-01 honda/acura.
There just isn't much room with the double wishbone up front.</TD></TR></TABLE>
and isnt necessary. small front bars FTW
Old Oct 23, 2007 | 06:52 PM
vtekthis's Avatar
Default Re: (Lo-Buck EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF &raquo;</TD></TR><TR><TD CLASS="quote">miller-are you guys building a road race car over there???
-spenc</TD></TR></TABLE>
prolly looking for some road racer insight on drag cars.... works well
or maby they are and i am just making stuff up lol
Old Oct 23, 2007 | 09:18 PM
Banned
Yep. Stock front bars are all you need. No more.
Old Oct 25, 2007 | 12:53 PM
STN_Pat's Avatar
progress 24mm unit is slotted to it's end wich makes it adjutable
it is a great bar I liked it.
Old Oct 25, 2007 | 08:15 PM
miller's Avatar
Default Re: (STN_Pat)
I actually have a customer who wants to build a sick road race car, this thing will be really sick. The road race experience i have is limited to trans am series cars and toyota atlantic cars.
We could fabricate one no problem, i was just seein if there was someone who offered a readily available off the shelf unit to save tis guy some cost.
Old Oct 25, 2007 | 08:27 PM
Default Re: (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">I actually have a customer who wants to build a sick road race car, this thing will be really sick. The road race experience i have is limited to trans am series cars and toyota atlantic cars.
We could fabricate one no problem, i was just seein if there was someone who offered a readily available off the shelf unit to save tis guy some cost.</TD></TR></TABLE>
http://www.asr-racing.com Charelston his is HT SC sells a rear one. I couldn't peace together a kit like theres for less then they sell it.
As for the front, stock works great. And good luck putting a speadway eng type on the front of a 88-01 honda/acura. There isn't any room
Old Oct 25, 2007 | 08:36 PM
Lo-Buck EF's Avatar
miller-take it from me. a bigger than stock fromnt bar is not necessary. it will actually make the car handle worse cause it will push all the dam time
Old Oct 25, 2007 | 09:46 PM
vwong's Avatar
ASR's site has been changed to this, www.asrparts.com.
Old Oct 27, 2007 | 06:38 AM
miller's Avatar
Default Re: (vwong)
thanks for all the info guys, you have been a big help.
Spencer
Run Away
12
Aug 28, 2011 02:55 PM
austinkli
Suspension & Brakes
Mar 22, 2010 07:00 PM
made in JAPAN
Mar 15, 2004 05:18 PM
LCheung
Apr 18, 2002 08:01 PM
spork sport
Feb 22, 2002 03:51 PM
