using exterior paint... on interior?
Old Aug 29, 2008 | 03:31 PM
rewerbcrx's Avatar
Default using exterior paint... on interior?
i have painted several things on the exterior of the car... i have never painted interior pieces using real automotive paint.
question...
on the door panels there is padded vynl on most of the door panel. what is the recommendation for this? can it be painted right over? using adhesion promoter then your primer base and clear?
im just not a professional so i do not know the answer. but my work is very good.
Old Aug 30, 2008 | 08:41 AM
rewerbcrx's Avatar
Default Re: using exterior paint... on interior? (rewerbcrx)
bump?
Old Aug 30, 2008 | 05:13 PM
rewerbcrx's Avatar
tiny bit of help
Old Sep 5, 2008 | 03:43 PM
rewerbcrx's Avatar
no?
Old Sep 5, 2008 | 03:55 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">
Why are you trying to paint vinyl, when there are dedicated products to dye it instead?
Check this thread:
https://honda-tech.com/zerothread/2114271
Old Sep 5, 2008 | 11:12 PM
Eyger's Avatar
You're not going to want to paint right over the vinyl on the door panel. I don't think it'll stay. Well, It'll stay for a while, but I would imagine it'll fall off after being exposed to different temperatures and being touch and having pressure on it.
You can use a dye to change the color of the vinyl, and that'll last pretty much forever I believe. (Ive never done it)
Most of the interior's i've seen where they paint pieces of the inside with an actual auto paint, have been one of two things. One being a fiberglass replacement, aka fiberglass door panel or something of similar nature, then painted on top no problem, same way as outside. And secondly, is just to paint the plastic pieces such as plastic trim rings, radio consoles whatever.
Another option might be, you might be able to pull the vinyl off of the door and paint whatever is under it, which I would thing is most likely plastic.
Old Sep 6, 2008 | 11:37 AM
rewerbcrx's Avatar
Default Re: (Eyger)
i assumed that fiberglassing was the way. TY
AaronD
Jan 20, 2009 06:46 PM
twiztid00002
Paint and Body
Nov 18, 2008 07:38 PM
HondaGuy4Life
May 23, 2007 04:36 AM
teejlc
Paint and Body
Apr 23, 2007 07:20 PM
melovesboost
Paint and Body
Apr 22, 2007 05:30 PM
