Nason paint?
hey i just bought 3 qts. of Nason Paint. not sure how good this paint is? has anyone in here used that brand? if so how is the quality on them?
any advice on what type/brand of primer i should get? any info will help. thankx.
we just resprayed the engine bay with nason paint. it was the cheapest base that industrial finishes has, its just base. gonna get covered with clear so dont skimp out on the clear is the way we look at it.
as for the primer, are you spraying it on bare metal or a previous layer of base/primer?
thanks for the reply... i will be spraying 3 coats of Nason and 2 clear coats? will that work? or should i spray more clear coat?
as for the primer it will be previous layer of base/primer.
if your not stripping it down to bare metal...which should be avoided anyways if could, you can just use some urethane primer, i used nason primer as well. we shot about 3 coats of base and 3 or 4 coats of clear because were **** and wanted some depth. just remember, whatever the primer looks like is what your finish will look like. spend lots of time sanding the primer before layind down the base...unless you plan to wetsand the base as well.
thanks for the advice and information! really really helpful.
that leads me to another question.
Like a NEWBIE i didnt do my research before sanding down my fenders. the fenders are sanded down to bare metal. i used a Krylon Primer. the name of the krylon was Rust Tough? should i resand it down and spray it with a different type of primer?
drumminforev
Dec 8, 2006 10:10 AM
