How to paint shift knob numbers?
Old Aug 21, 2009 | 11:58 AM
gwiffer's Avatar
Icon2 How to paint shift **** numbers?
What is the best way to paint the shift **** (6spd) numbers red?
Thanks
Old Aug 21, 2009 | 03:53 PM
94 DX Hatch's Avatar
New User
Default Re: How to paint shift **** numbers?
I would try a very fine tip brush with some model enamel paint. Or, if you have a fine tip Sharpie, that might work just as well.
Old Aug 21, 2009 | 09:47 PM
97ShLude's Avatar
there is a trick you can do with a red crayon that works perfectly for this, I bet if you search for it a bit you should find exactly how to do it
Old Aug 22, 2009 | 10:35 AM
Eyger's Avatar
I guess it depends on the ****, lets say it's a metal ****, you could probably just paint the whole top of it, then sand it with a flat black to get rid of everything except whats in the indented numbers, then use a higer grit to get it back to a brushed metal look.
Old Aug 23, 2009 | 10:10 AM
JSPECSIR's Avatar
i used a toothpick and testors model paint. then just wiped over the top of the **** with a paper towel and laquer thinner to clean any excess. leaving the paint only in the numbers.
Old Aug 23, 2009 | 05:51 PM
DrAzTiK87's Avatar
melt the crayon on it, and wipe off before it dries...
Old Aug 23, 2009 | 08:19 PM
prelude1897's Avatar
that's what I've heard to do as well....
Old Aug 24, 2009 | 01:38 PM
ekslammed's Avatar
i used red nail polish haha
Old Aug 24, 2009 | 03:27 PM
SneezinCD5's Avatar
Crayon is the best way.
Old Aug 24, 2009 | 06:30 PM
teggsr925's Avatar
i just used model paint and painted the whole top and wiped it off. the numbers stayed painted
Old Aug 24, 2009 | 08:07 PM
creepass's Avatar
dont use crayons, it melts on a hot day, not a good idea. my brother did it.
Old Aug 28, 2009 | 09:57 AM
hilaaryjohn72's Avatar
hey friend i also dont have much idea about it...can anyone solve this problem or answer this question?
Old Aug 28, 2009 | 10:44 AM
SugarsEK's Avatar
this is what i would do. use a fine tip brush and some paint. just take your time. be careful, and keep a rag or paper towel on hand to wipe off any extra. i also wouldn't go with the crayon because like stated above if it gets hot enough its going to melt again.
Old Aug 28, 2009 | 12:14 PM
thegatekeeper14's Avatar
i used wax and poured it in, then whiped off the rest,
pliskin679
Jan 15, 2013 03:47 PM
chafetzk
Mar 31, 2011 02:54 AM
HondaKyle
Feb 16, 2008 08:25 AM
JMD
Jan 12, 2006 07:45 AM
MilanoRedDC5
18
Sep 26, 2005 04:02 PM
