How Much Paint Do i Need?
Old Dec 5, 2009 | 12:04 PM
94_Teggy's Avatar
Default How Much Paint Do i Need?
Iam gunna paint my 97 4dr Civic And wanted to no how much paint/clear coat iam gunna need to paint the whole car(door jams and engine bay too)Thanks alot guys!
Old Dec 6, 2009 | 10:52 AM
prelude1897's Avatar
Default Re: How Much Paint Do i Need?
Are you repainting it a whole different color or just the same color? If you're doing a color change, I'd get at least 1-1.5 gallons of base paint cause after reducing it, you'll have 2-3 gallons of paint depending on the mixture ratio. You might not need it all, but it's good to have some left over just in case if something goes wrong. As for clear, you'll probably be fine with just a gallon of clear.
Old Dec 6, 2009 | 11:53 AM
FearTheH's Avatar
Buy 1 gallon of color, and get needed reducer. That should be more than enough... Also as said above if changing color, there's a chance you will need more.
Old Dec 6, 2009 | 02:10 PM
94_Teggy's Avatar
yes iam doing a color change.So paint wise all i need is 1.5 gallons paint,reducer and one gallon clear.
Old Dec 6, 2009 | 07:00 PM
FearTheH's Avatar
Are you doing the door jambs, engine bay, trunk jambs and all?
Old Dec 7, 2009 | 07:47 AM
he mentions that in his first post that he'll be painting all that
Old Dec 7, 2009 | 08:59 AM
94_Teggy's Avatar
Indeed!
Old Dec 7, 2009 | 10:42 AM
JLHDOHC's Avatar
Gallon color plus reducer and one gallon clear more than enough for that car as long as you use a proper sealer that will blend well with your color it will make it easier for coverage PPG DBC is awsome paint and for clear DC4000 or 2042 the dbc paint is a 1 to 1 mix so a gallon will make 2 after reduced so you'd have plenty left to
Old Dec 7, 2009 | 01:42 PM
Spawne32's Avatar
where you at in NJ?
Old Dec 7, 2009 | 02:44 PM
94_Teggy's Avatar
Originally Posted by Spawne32
where you at in NJ?
Toms River
Old Dec 7, 2009 | 02:53 PM
Spawne32's Avatar
Originally Posted by 94_Teggy
Toms River
motor car colors in moorestown can get you what you need, id go with the limco base/clear (limco 4100 clear) if your on a budget
http://www.motorcarcolors.com/contact.html
Old Dec 10, 2009 | 01:46 AM
paulthomas2's Avatar
New User
I think one gallon is sufficient but you need to buy reducer with it....it is sufficient to paint in this much....If you are not satisfied you can just contact dealor he will guide you right way
Stanced_b20
Dec 3, 2018 09:42 AM
jadeydrag0117
Paint and Body
Nov 8, 2012 12:21 AM
Draiga1988
Paint and Body
Oct 18, 2010 03:24 AM
messeduprex
Paint and Body
Jan 8, 2009 07:33 PM
