corrosion
Old Jan 21, 2011 | 11:37 AM
Bright13's Avatar
Default corrosion
I recently purchased an 02 civic si hatch. There is corrosion on all the aluminum parts in the engine bay as well as some rust on the the wiper arms, and various other small parts here and there. Overall the car is very nice, but I would like to help prevent it from spreading, and get rid of as much of it as possible. I was planning on looking into having it reundercoated, as well as treating and putting a new finish on some of the removable parts. What else can I do to help?
Old Jan 21, 2011 | 04:00 PM
jasoncrashtech's Avatar
Default Re: corrosion
aluminum rusting ? (aluminum doesn't rust)
sand and prep all surface rust area's, clean , coat with primer , then base coat/clear.
pic's would be helpful
Old Jan 21, 2011 | 04:54 PM
night's Avatar
he means the white crustiness that develops on aluminum.
Old Jan 21, 2011 | 08:17 PM
toyomatt84's Avatar
Sanji
Which is actually oxidized aluminum. And, to be honest, oxidized metal is technically "rust". It doesn't degrade as quickly as oxidized steel, though.
Example:
Old Jan 21, 2011 | 09:52 PM
Bright13's Avatar
I should be able to post some pictures tomorrow. There doesn't appear to be any actual body rust, just on wiper arms and maybe one or two other pieces, but I suppose that doesn't mean there isn't any. And of course the aluminium oxidation.
Old Jan 22, 2011 | 10:34 AM
Bright13's Avatar
Here are some pictures, just various areas.
Old Jan 24, 2011 | 10:49 AM
toyomatt84's Avatar
Sanji
For the aluminum oxide, I'd recommend Bar Keeper's Friend, Copper Glo, or some other form of metallic cleanser. For the rusting steel components, you'll need either some sandpaper or maybe just some steel wool. But, you'll need paint to cover up any exposed steel.
Ryank327
Mar 10, 2011 05:25 PM
undeniabl3niguh
Jan 20, 2006 06:48 PM
EiksITR
Jun 2, 2002 03:39 PM
