bondo help!!!!!!
Old Apr 19, 2007 | 05:12 PM
MY_EF_NINE's Avatar
Default bondo help!!!!!!
anyone know a good place to buy bondo and what type of bondo i should get...????
Old Apr 19, 2007 | 05:19 PM
John M's Avatar
Default Re: bondo help!!!!!! (MY_EF_NINE)
walmart, and auto store like auto zone or advance. Just get the size you need.
-NA-aLL-thE-wAy-'s Avatar
EFSS153
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MY_EF_NINE &raquo;</TD></TR><TR><TD CLASS="quote">anyone know a good place to buy bondo and what type of bondo i should get...???? </TD></TR></TABLE>
Don't make the mistake of calling all filler "bondo." That's like calling all tissue "Kleenex."
I've got friends that swear by Evercoat Metal Glaze and others that swear by USC Icing.
There is info in these two posts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [b]<u>Engine Bay "Icing" or "Filler" &raquo;</TD></TR><TR><TD CLASS="quote">USC ICING
Slappy: "I think that's what (Bryan) Pandahatch used.......Ive heard good things about that one."
OR
Link for Evercoat Metal Glaze:
http://www.evercoat.com/productDetail.aspx?pID=1
Pic for Evercoat Metal Glaze:
http://www.evercoat.com/imgs/p...e.jpg </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [b]PandaHatch on <u>Fillers/Bondo... &raquo;</TD></TR><TR><TD CLASS="quote">DO NOT USE BONDO!!!!!
There is USC Icing and Evercoat Metal Glaze. Take your pick, they're essentially the same.
I did ALL my sanding by hand, except for the core support otherwise I used a DA, EVERY contour is and done, I feel when working with complex shapes, you can get a better feel with hand.</TD></TR></TABLE>
I plan on getting the USC icing because I can use it to fix my oem plastic bumpers and to smooth things out in the engine bay. I might also use some to smooth out a couple dings on the body.
Old Apr 19, 2007 | 05:21 PM
Boosted Chemist's Avatar
Default Re: bondo help!!!!!! (-NA-aLL-thE-wAy-)
usc and evercoat brands seem to be the better quality stuff.
Old Apr 19, 2007 | 05:53 PM
jakeiscool's Avatar
Banned
Default Re: bondo help!!!!!! (Boosted Chemist)
we used to use evercoat, never used anything else so i cant say anything pos or neg about it. fiberglass filler seemed to be the best. use as little as possible though. "bondo" pancakes look worse than small dents.
Old Apr 19, 2007 | 06:39 PM
B16B_coupe's Avatar
HRD PKR
Default Re: bondo help!!!!!! (JakeIsCool)
most things these days wont need bondo.. most stuff is replaced now a days.. but i agree with above^^ metal glaze!
Old Apr 19, 2007 | 07:20 PM
kiddcarbuff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">usc and evercoat brands seem to be the better quality stuff.</TD></TR></TABLE> def good quality stuff. its all i use
Old Apr 19, 2007 | 07:24 PM
Ohgodzirra's Avatar
if you are doing a larger area that would require a big fill, i.e. antenna hole, use a fiberglass with a piece of metal welded in from behind the hole. Filler is made just to fix things that are the size of small paint chips or divits left from fiberglassing.
Old Apr 20, 2007 | 09:32 AM
96GSRcx's Avatar
Default Re: (Ohgodzirra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ohgodzirra &raquo;</TD></TR><TR><TD CLASS="quote">if you are doing a larger area that would require a big fill, i.e. antenna hole, use a fiberglass with a piece of metal welded in from behind the hole. Filler is made just to fix things that are the size of small paint chips or divits left from fiberglassing.</TD></TR></TABLE>
I think there's a reason they call it filler and not diviter, Paint chips aren't supposed to be filled with a filler, they should be featheredged sanded, then that spot filled with high build primer. Pin holes in fiberglass and paint is filled with 1 part putty. Large dents and areas needing 1/8" or less require "bondo" or a plastic filler. And for small dents, use metal glaze or icing. I do agree about the welding metal in the antenna hole you mentioned, though plastic or fiberglass will work the same.
Modified by 96GSRcx at 2:46 PM 4/20/2007
Old Apr 20, 2007 | 10:37 AM
rare_db2's Avatar
Default Re: (96GSRcx)
RAGE! is the way to go its the worlds premium light weight filler.
Old Apr 20, 2007 | 02:59 PM
mike9571's Avatar
Default Re: (rare_db2)
Bondo is one of the worst fillers out there. I love zebra, also look for anything by evercoat
Old Apr 20, 2007 | 07:34 PM
Danger's Avatar
Default Re: (mike9571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">Bondo is one of the worst fillers out there. </TD></TR></TABLE>
the truth ! whenever i see pinkish / red bondo spots it drives me crazy
Old Apr 20, 2007 | 08:05 PM
Ohgodzirra's Avatar
I didn't mean normal shallow chips that can be feathered, more of the chips that go deep enough that either metal is exposed, or when 320 will not feather the area properly and bringing the chip even would cause a cratering effect around the area. Yeah, 1/8th inch sounds about right for what you are talking about icing works wonders!
Old Apr 26, 2007 | 07:14 PM
dc5r2002's Avatar
Use the evercoat rage to fill anybigger imperfections after you straighten the metal then feather it out into the paint, then use the evercoat metal glaze and go over the DA scratches where you featheredged onto the paint then block it all out 80 just to cut the glaze down a very light sanding then 180 then 320, dont try to fill anything but pinholes with the metal glaze its not made to fill.
Old Apr 27, 2007 | 11:19 PM
vsmhatched's Avatar
Default Re: (Danger)
evercoat is a way better brand then bondo
Old Apr 28, 2007 | 03:19 AM
harmonator84's Avatar
Default Re: (GreyDel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel &raquo;</TD></TR><TR><TD CLASS="quote">evercoat is a way better brand then bondo</TD></TR></TABLE>
X12984719851
Old Apr 28, 2007 | 02:03 PM
Slick's Avatar
I use anything. Evercoat, Bondo, whatever. It's not the plastic, it's the man behind it that counts. I prefer short-hair glass or monkey hair for larger work. Plastic should only be used for smoothing and finishing.
Old Apr 28, 2007 | 02:15 PM
Default Re: (Slick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slick &raquo;</TD></TR><TR><TD CLASS="quote">I use anything. Evercoat, Bondo, whatever. It's not the plastic, it's the man behind it that counts. I prefer short-hair glass or monkey hair for larger work. Plastic should only be used for smoothing and finishing.</TD></TR></TABLE>
I have heard of tiger hair but never monky hair...
hmc118
Jan 18, 2008 11:25 AM
Beans90crx
Nov 26, 2007 05:12 PM
1Quikgsr
Oct 30, 2006 06:53 PM
jason DB8
Oct 5, 2006 11:55 AM
Piwok
Mar 19, 2006 06:59 AM
