1993 CIVIC HATCHBACK ALL MOTOR b18 in NJ
Pix are here:
http://newjersey.craigslist.org/cto/1161153663.html $5999 CALL 862-242-0108 PLEASE NO TRADES UNLESS IT IS A STOCK CIVIC/ACCORD OR A MUSCLECAR POWER Engine has less than 10k on it since rebuild GSR block bored out to 81.25 JDM B16a1 head (red top) Skunk2 springs Skunk2 Stage 2 Cams Skunk2 Valve Retainers Skunk2 high compression valves Skunk2 Silver Cam Gears Skunk2 pro-series intake manifold 3 angle valve job, bored, honed, decked ERL 5 main girdle Toda Timing Belt Golden Eagle Cam Seal AEM fuel pressure regulator AEM fuel rail AEM short ram intake B&M underhood fuel pressure guage DSM 450cc injectors, prelude resistor box walbro 255Lph fuel pump ARP head stud kit ITR oil pump ITR water pump ITR JDM 81.25mm oversize pistons NOLOGY fat plug wires and NGK plugs OBX 4-2-1 header (get rid of this first thing if you buy the car) DC sports short throw shifter/type r knob Custom made exhaust with thrush glasspack before ebay fartcan, sounds real throaty, not ricey at all. 2 1/2" pipe into 2" pipe EX cluster throttle body bypassed Valve cover cut for easy access to timing gears cat removed in favor of resonator A/C removed OBD-1 p72 ECU tuned on HONDATA s100 Dyno and street Tuned by Jeff Evans of Evans Tuning, easton PA All motor build work done by buxbaum bros. machine shop in NJ ROLLERS Tokico illumina 5 way adjustable struts on matching illumina springs. -15x6.5 Rota Group N wheels w/yokohamas rear disc brake conversion from gsr brembo blank rotors with hawk pads Energy suspension bushings,(red) full kit. APPEARANCE/COSMETIC type R front lip type R rear lip wings west Racing Series (rs) side skirts spoon mirrors 13% tint on all windows tyc black housing 1pc projector headlights Sparco harnesses w/ sparco pads custom rear upper strut bar welded in ready to be turned into a cage painted black in 07 Interior half gutted, metal painted black |
Re: 1993 CIVIC HATCHBACK ALL MOTOR b18 in NJ
Bump
Originally Posted by BLUCIVICSl2
(Post 38494723)
^^^. annnnd a bump
How much power did it make
