Motorcycles Motorcycles and motorcycle parts for sale
about cbr 1000rr 2009
Old Nov 21, 2017 | 03:43 AM
aliabdeen's Avatar
Default about cbr 1000rr 2009
hello i have cbr 1000rr 2009 and i have a problem with its crankshaft so i have to change the connecting rod bearing ,, so i want to know the colour of the bearing and its thickness by taking in consideration the crack shaft have an erosion in the connecting rod so i will change in the crank shaft connecting rod diameter will lose 0,01 from its diameter and i want to know the most suitable color ( bearing ) to the connecting rod
thanks in advace
Old Nov 21, 2017 | 07:42 PM
Doodasi's Avatar
Default Re: about cbr 1000rr 2009
If you spun a rod bearing, you need to measure the connecting rod, and crankshaft journal with a micrometer, and dial bore guage, or equivalent. If anything is out of spec, it will need to be resized, or replaced. The crankshaft will need to be micro polished. If you do not micro polish a crankshaft properly even though it is within factory specifications, it may cause premature bearing falure. If you know what the sizes of your connecting rod, and crankshaft rod journal are, there should be a factory size chart somewhere for the proper bearings. Motorcycle honda parts department has this too. You can always double check your work with a plastiguage, and buy one or two new bearings if needed.
AssPenny
13
Feb 22, 2014 07:51 AM
Phoenix5
Honda Civic (2001 - 2005)
Dec 23, 2013 11:07 AM
dj-t
Jul 2, 2009 08:48 AM
Mugen112
Oct 18, 2006 11:52 AM
