Tail light problem
1995 Honda Accord EX Coupe.
I just replaced my taillights. Now the light on the driver side won't light up when I turn the lights on.
It will light up when I step on the brake.
I don't see any loose wires.
Any help... Suggestions?
Thanks
*EDIT*
OKay... So now the passenger side light won't light up when I turn the lights on.
And now the Driver side won't light up when I step on the brake.
The Reverse lights and turn signals work on both sides
I really need some help
Thanks
*EDIT*
First thing would be to check the fuses. Second would be to check the bulbs... I believe that is a double filament bulb for your light/ stop light. You can see if the little filament is broken by looking at it. Then I would look at the harnesses where those plugs go into to see if they are burnt.
Also, are you leaving your car on when you are installing / uninstalling bulbs (don't)? Do you have any weird/custom wiring going on in your car?
Dru-Si
11
Jun 2, 2002 08:38 PM
