Lighting HID/Xenon kits, Retrofits and Associated Topics
Single Headlight issue
Old Jan 20, 2014 | 11:04 PM
Charismatica's Avatar
Default Single Headlight issue
Passenger side HID went out. Before it did it was blinking and flickering for a few weeks. So it didn't just go out one night and not turn on again
Checked all the fuses. They are good now.
Got a new HID kit, still doesn't work.
Checked the connector with a tester and gets no power.
Anyone have any idea? Wiring issue? \
thanks
Car is 2000 Ek
Old Jan 21, 2014 | 05:03 PM
k_than's Avatar
Default Re: Single Headlight issue
checked fuse 21 and 22?both are good?
if no power with tester has to be blown fuse or broken wire
Old Mar 2, 2014 | 10:47 AM
kyle_holland053's Avatar
I am having the same issue with my passenger headlight. Checked both fuses and they are good
Old Mar 3, 2014 | 02:17 PM
TheFamilySign's Avatar
do the highbeams work??
check wiring.
it may be just the bulb
Old Jun 2, 2014 | 05:27 PM
D16terror's Avatar
I had a ballast that was going bad. I switched the box from one side to the other and then the other side started flickering.
Old Jun 20, 2014 | 09:18 AM
LVFreeze's Avatar
I have the same problem. Passenger side will flicker occasionally
Haulinbass08
Jan 22, 2015 05:13 AM
notstock93
13
Aug 14, 2006 03:24 PM
RSX_TypE-1
17
Jun 21, 2006 07:23 PM
GapxGuy
Feb 20, 2005 10:23 PM
damarksman
Sep 14, 2001 08:41 AM
