Retrofit assistance
is there anyone in the NYC area, preferably in Long Island that is willing to help out with the installation of retrofits?
Recently purchased the full setup from retrofitsource but am afraid of messing up. Car is a ek coupe.
Just stick your headlight in the oven for like 2-3 mins in low heat just to get the headlight glue soft then pry it open. make sure to set your headlight on something in the oven so the metal don’t melt the plastic.
stick your projector in nice and tight then go test on car make sure they straight and aligned.
put lense back on head light best as possible then stick in the oven again for another 2-3 mins to soften the glue again. then give them another squeeze just to make sure they are closed good.
thats it shouldn’t be to bad, use more glue if needed to seal them from moisture
aJDMchampioN
Jul 23, 2004 10:10 AM
