Lighting HID/Xenon kits, Retrofits and Associated Topics
Removing headlight glue and silicone
Old Mar 28, 2009 | 07:53 PM
Andy_EJ8's Avatar
Default Removing headlight glue and silicone
I redid my retro-fit a few days ago, now since its been raining and my headlights has moisture in it. What is a good product to remove headlight glue and silicone? I try oops and that did not work. Would acetone work or should I just heat the glue and silicone out and try to remove it that way? I want to remove all the glue and start the resealing process over again.
Old Mar 28, 2009 | 08:57 PM
98civdx's Avatar
Master Detailer
Default Re: Removing headlight glue and silicone
heat it up and try to get as most as you can off.
oops? like the knock off goof off?
that crap never works for anything lol.
Old Mar 29, 2009 | 01:22 PM
zsudz922's Avatar
^^i agree, i would try heating it up to get if off first. you could try using a dremel with a brass wire tip to get it off. thats what i used when i took apart my fog lights. it work very well actually.
Old Mar 29, 2009 | 03:33 PM
Andy_EJ8's Avatar
thanks 98civdx and zsudz922, I guess their is no easy way to do it.
will try the heat gun again on tuesday.
Old Mar 29, 2009 | 04:32 PM
MILF_HUNT3R's Avatar
i had same problem soo i went back with a heat gun like the first time was to lazy to go to the store and buy the silicone and learned the hard way when i seen em on a rainy day soo i redid em and put slilcone and bamm it could rain alll day and they still good hope this was helpfull enough
Old Mar 30, 2009 | 01:01 AM
98civdx's Avatar
Master Detailer
nope there is no easy way.. pays to be carefull.
BlueIntegraBoy
Sep 7, 2008 05:34 PM
petrv
May 6, 2003 10:11 PM
ih8danoles
Apr 21, 2003 12:21 PM
HatchBox
Dec 18, 2002 03:16 PM
Dan GSR
Aug 21, 2002 09:39 AM
