HID or LED Retrofit for EG?
Weird, this doesn’t look like an HID projector.
https://www.morimotohid.com/morimoto...lbs?quantity=1
I'm excited to get my passenger headlight + duct combo set up.
I did find another 3D printed headlight from a different seller online that actually looks a little better than mine, but I still think it'll come out pretty neat.
I clearly didn't read well enough
I thought it was the projector retrofitted with the bulbs. They definitely need to be replaced with a proper headlight projector.
.I thought it was the projector retrofitted with the bulbs. They definitely need to be replaced with a proper headlight projector.
I could not tell if it was a proper HID projector in the Denji housing.
I haven't heard back from Inline4, so I am not too sure how legit they are.
I have gotten some email replies from Denji, but they won't answer any of my questions, they just want to know how many I want to buy.
I already have some Spec-D smooth glass housings, I think I will just call the Retrofit folks and get some Mini H1 bi-xenons and stick them in there.
If the inline4 posting is correct, it’s a halogen housing with an HID bulb.
While it might work, and you’ll probably not get a ticket these days, you’ll probably still want to do a retrofit with those housings for the ultimate output.
And if you’re going to spend the money to do that, you might as well just do a bi-xenon retrofit from Morimoto in some clear lens housings.
I saw these as well, but when you put them in the cart, the only option is LED.
I know less about LED projectors than I do about HID.
https://visionautoworks.com/blogs/vi...h1-7-0-bixenon
I saw here TRS has a LED retrofit kit: https://www.theretrofitsource.com/bi...LED?quantity=1
Any thoughts?
Any thoughts?
Has anyone tried these?
Is it a projector low beam and an H1 in a reflector high beam?
No electronics to light the H1s?
https://www.amazon.com/Spec-D-Tuning...ef_=ast_sto_dp
https://store-ukxm8kuqej.mybigcommer...-CV923_-TM.pdf
